2005 prius weird behavior. It won't start.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Fedejunin, Aug 21, 2019.
  1. bisco
    52,860
    can you jump it from another car to see what happens? your battery is close to failing, so it would be smart to eliminate it as a possibility, before diving headfirst into the hybrid battery
  2. Fedejunin
    Fedejunin Junior Member
    Ponte Vedra
    Battery was checked at the shop. It shows good voltage. Also o tried to jump it from another car and nothing happens.
    I have a agm battery charger, so I diddid cha it to 100% last night. Nothing changed.
    52,860
    it looks like some sort of short, maybe a loose wire or bad solder joint behind the dash?
  4. Fedejunin
    Ponte Vedra
    I don't know. I am trying to find a guy that share inia forum the same problem years ago, unafortunatel he didn't post how he solve it.
  5. Fedejunin
    Ponte Vedra
    2 Toyota's retired mechanic saw the car, they couldn't identify the problem, at least they didnt charge me anything. Tomorrow the car will have a full inspection at the Toyota dealer. I tried everything but take it to the source. I know they will want to replace everything electronic just to be sure. I will post what was the problem next week. No one, absolutiley no one in 3 differents Toyota pages have hear of a problem like I have.
  6. Patrick Wong
    18,210
    6,522
    The following are the suspect areas since the Prius will not become IG-ON:
    Power source control ECU
    AM1 fuse
    AM2 fuse
    IG1 relay
    IG2 relay
    Wire harness
    donbright likes this.
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    The way everything is flickering it sure does sound like it could be a relay chatter type issue. Would be nice if that's all it is.
  8. Fedejunin
    Ponte Vedra
    To everyone. Finally I have the car running again. The problem was the ecu, it was fried. Main reason OBD didn't work. I bought a used ecu from.ebay ($25) . replaced it. I had to reset it and the car just started. After that I had errors with brake, abs and vtc. A mechanic wanted to charge me around $2000 to replace all the brake system, trying to sell me that this is a comĂșn problem. I did not pay for that, instead I used my foxwell nt520 and I reinitialized the brake system. No more warning lights, car drives perfect.
    chaosphere, donbright and bisco like this.
  9. bisco
    52,860
    wow, congrats and well done!(y)
  10. chaosphere
    chaosphere Junior Member
    22
    France
    What was the procedure to reset the ECU please ?
  11. Archway
    Archway Junior Member
    Austin TX
    I had the boxes also and tried replacing the ECU and it didn't work. For future people with similar problems, be sure to check easy stuff like the AM-2 fuse before pulling apart the whole dashboard to get out the ECU like I did. o_O
