2005 Prius went totally dead, but came back
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dex3703, Feb 3, 2025.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,122
    555
    Alberta
    2024 Prius Prime
    XSE
    A loose clamp could have caused it, but no one knows what other reasons might have caused it.
  2. pasadena_commut
    pasadena_commut Senior Member
    2,582
    764
    Southern California
    Was the connector all the way down on the post? I don't recall if this is the case for the Prius 12V, but at least some battery terminals are not cylindrical, instead they are slightly conical (base part of the cone, the pointy part is missing). If the connector is not shoved down all the way to the deck of the battery on one of those the connector "loop" may close fully without getting a very good grip on the post and then it could work loose.
    Also, I'm not sure if this is what you meant, but I never put dielectric grease between the post and the connector. The grease is there to prevent corrosion, it goes over the top of everything once assembled to keep water and air away from the metal. If there is grease between the post and the connector it is lubing a junction which is not supposed to move, which is counterproductive.
    dex3703 and Brian1954 like this.
  3. dolj
    dolj Senior Member
    8,416
    4,283
    Wellington, New Zealand
    All automotive battery terminals are conical as you describe. That is why it is important to open up the clamp before reattaching it and ensuring the clamp is firmly seated all the way to the bottom of the post.
    Remembering to first loosen the clamp and force it open a bit before attaching and tightening.
    I 100% agree. I do not use any corrosion countermeasure and the battery posts are 100% corrosion-free, unlike the (good) old days of unsealed batteries.
    dex3703 likes this.
  4. Paul Gregory
    2,122
    555
    Alberta
    2024 Prius Prime
    XSE
    There is a paste that's supposed to prevent corrosion in battery terminals.
  5. dex3703
    dex3703 Member
    59
    30
    Seattle
    I'll check, but I'm sure the connector was pushed all the way down on the post, flush with the battery. With all the stuff hanging off that connector, it's hard to press down, or be sure if it is. Behaving much better so far.
    Are there such things as shims for battery posts?
  6. pasadena_commut
    2,582
    764
    Southern California
    Not that I have ever heard of, but since it would just be a little piece of lead, probably?
  7. dex3703
    dex3703 Member
    59
    30
    Seattle
    Turns out there are such things.
  8. Paul Gregory
    2,122
    555
    Alberta
    2024 Prius Prime
    XSE
    I'd be more inclined to use a battery with the proper terminal size.
  9. dolj
    dolj Senior Member
    8,416
    4,283
    If you can't turn all that palaver on the positive terminal by hand, I'd leave it alone. You've found your answer.
    Yes, but those shown two posts back are designed to shim a JIS (Japanese Industrial Standard) terminal post to an SAE (Society of Automotive Enginers) standard Terminal post. It would only be useful if you were using the OEM battery (or equivalent) with a JIS post and someone had converted the post clamps to an SAE clamp. If you can get it tight without, I'd leave well enough alone.
