2005 Prius Will not start; boxes instead of dash lights, HELP!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mrs.Diamond, Feb 20, 2018.
  1. strawbrad
    953
    1,007
    Good Morning!
    You really should have titled this thread " A Diamond In The Rough " ;)
    I have seen this before. I never got to a solution on that car. Are the squares around the P R D N B? The dash on a 2005 is laid out differently than your newer Prius.
    The service record said there was no inverter coolant. Get under the car and look for leaks. That's the first place to check.
    Brad
    fotomoto likes this.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Classic dead inverter pump inverter over heated and crow barred and the owner drove it on the hv battery
    Till it died.
    So most likely no matter what you replace on the chassis the car cannot start with a dead or very low hv battery.
    Hv battery spins mg1 and that spins up the ICE. NO hv battery no nothing except 12 volt system and lots and lots of dtc’s.
    You need a hv battery charger like a prolong. Open up the hv battery and measure at the relay battery side the battery output.
    pashko90 likes this.
  3. Mrs.Diamond
    Mrs.Diamond Junior Member
    66
    Minneapolis, MN
    HV battery tests just fine 225 volts. If this is a $55 fix for a inverted pump at the salvage yard I’ll be very very happy. Dear Lord, I’m only hoping to find an inexpensive netbook to run this Techstream on.
  4. Mrs.Diamond
    66
    Minneapolis, MN
  5. dolj
    dolj Senior Member
    8,655
    4,406
    Wellington, New Zealand
    Don't bother getting a second-hand pump. It is a wear item, so just get a new OEM one – it'll only cost $40-50 more for 100,000 mi peace-of-mind.
    pashko90 and JC91006 like this.
  6. Mrs.Diamond
    66
    Minneapolis, MN
    So I’m an effort to help me change out the HV pump on this car my husband sheered off the bolt that sticks up. Any advice?
  7. bisco
    52,891
    easy out?
  8. JC91006
    16,939
    8,647
    There's another bolt on the side of the bracket that the sheered off bolt is located. Remove that bracket to take out the HV pump.
    You probably don't have to replace that bolt....there should be enough bolts there to hold it tight.
  9. Mrs.Diamond
    66
    Minneapolis, MN
    Haha yeah but it was the bolt that sticks up and only the nut is supposed to come off it holds up another bracket and now I’m a bit worried. Does this need to be fixed?
  10. Mrs.Diamond
    66
    Minneapolis, MN
    I’m hoping to get this car running tonight for the first time since I purchased it. I’ll update the thread later tonight. Prayers appreciated.
  11. bisco
    52,891
    done, all the best!(y)
  12. Mrs.Diamond
    66
    Minneapolis, MN
    Update: the silver Prius that hasn’t ever run since I bougght it weeks ago just started!!!! It needed
    a new HV pump
    A 15 AMP AM2 fuse
    A new 12 volt
    A recharge of the HV battery
    Oil change
    More coolant added to the radiator
    I’d like to thank everyone who helped me on this thread: I can’t wait to see what- if any codes it pulls when I plug in Techstream. Need to air up the tires add in the crash brackets on the HV battery and take her out for gas and a road test drive. I can’t wait!
    JasonATX and bisco like this.
  13. bisco
    52,891
    well done!(y)
  14. Mrs.Diamond
    66
    Minneapolis, MN
    Never thought I’d be the one turning a wrench but man! This was FUN.
    dolj and bisco like this.
  15. Mrs.Diamond
    66
    Minneapolis, MN
    Only codes the car runs are
    C1241
    C1242
    C1300
    I’ll be trying the 12v of my first Prius to see if that solves the codes.
    I also have no speedometer showing up. I plan on using Techstream to reset the codes after the battery reinstall, hopefully that will clear it all up. They just brakes as they are squeaky after sitting for 3 months. Also the floor carpet is SOAKED on the drivers front seat. I do mean SOAKED. I wet vacuumed up what I could. I know this is not a flooded car. I have no idea where the wetness comes from. It’s mainly on the drivers side. Should I put rice down?
  16. valde3
    valde3 Senior Member
    2,002
    751
    Finland
    All of the codes with freeze frames seem to have very low 12V system voltage. So there’s a good change that replacing the 12V battery would fix them.
    The water is in the drives footwell and nowhere else? Not in the rear of same side? Not in the spare wheel area? Not in the passenger side? Seems to be weird location for water leak. Clean it and let’s hope the water doesn’t come back.
  17. Mrs.Diamond
    66
    Minneapolis, MN
    @valde3 I replaced the 12V and it cleared those codes. From the looks of it the back window cracked. No no signs of water anywhere else. Not an insurance flooded car. Running a few other codes after 400 miles of test driving. Pulling the am2 fuse solved them and car restarted and drove again. The main codes are P0420 and P0A09. I’m looking up the procedures now to test and / or replace these parts.
  18. Patrick Wong
    18,214
    6,530
    DTC P0420: catalytic converter efficiency is low. You will need to replace the catalytic converter.
    DTC P0A09: DC/DC converter in the inverter has failed. Use a voltmeter to measure voltage across the 12V battery when the Prius is READY. What voltage do you measure? It should be ~13.8V if the DC/DC converter is working.
  19. justheoh
    justheoh New Member
    Washington
    Posting here to say thank you so much for this thread, my 2005 Prius while driving on the highway stopped accelerating, went red triangle, when I had pulled over to the side it shut off, and then when I tried turning it back on the same problem with the boxes on the dash started happening.
    I had to get it towed (with it stuck in park so that was fun), I got lucky and was able to fix it by replacing the fuse and using the Dorman OE Solutions Drive Motor Inverter Cooler Water Pump from O'Reilly's the same day. I got lucky and did not need to recharge the hybrid battery and my 12V battery was perfectly healthy when checking with a multimeter, all I had to do was replace the Inverter Water Pump and fuse and the car has been fine for about 1000 miles since.
    Had I not found this thread I'm not sure what I would have done
    I had noticed earlier in the week that the car struggled a bit to turn on, such as the dash lights being a little dim for a bit, so maybe that was a sign of it failing.
    Brian1954 likes this.
