2005 Prius Will Not Start....Sometimes....
Discussion in 'Gen 2 Prius Technical Discussion' started by sunking989, Jun 1, 2011.
  1. sunking989
    sunking989 New Member
    Levittown, Pa
    Hi there...OP here...Have you had a lot of issues with your vehicle that has forced you to have to get hands on and involved with the inner workings of your vehicle? Sounds to me that you are not necessarily happy with your vehilce or it's dependibility. With the two posts you have made in this thread, it sounds like you aren't buying what I am saying? Think I am trolling here? I don't think that the tone of my question or my response would indicate anything other then the fact that I have run into an issue and was reaching out to a group of people that I knew know more then I do about the vehicle. Is it really that difficult to believe that I have had no issues with my vehicle? I don't get where you are coming from with the tone of your questioning.
    Oh...and BTW...No, I did not change the oil in my car, I had all regular/scheduled maintenance done at my local Toyota dealer. Again, a great experience with a great car until just recently.
    Once again, that you all for your suggestions and help. It has been greatly appreciated!
  2. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    OK, I see you are going to get a battery. Be advised when you disconnect the battery you will loose all your radio pre-sets and the window auto-down will be unhappy. The window is easy. Roll down 1/2 way, then roll up and hold up switch until it beeps. The radio is your baby. ;)
    As for the battery install:
    Remove hatch floor then cargo container.
    Remove small cover over the battery on the right side.
    Now you can see the battery. Remove the negative cable first. This is to ensure that any slip of the wrench will not result in disaster (if you ground the wrench there are no consequences as you are working on the ground). Once the negative is disconnected, the positive terminal can be accidentally grounded with no consequences. Do be aware that there is a large capacitor bank (to enable emergency braking in the event the battery disconnects while driving). It's the large black device in front of the battery. It will be charged and may discharge if you short it.
    You will have "fun" getting the red cover off the positive terminal. Be patient and work it off.
    Take care to reconnect the battery breather tube.
    It's easy enough. You just have to have some patience.
  3. Patrick Wong
    18,210
    6,516
    It actually is unnecessary to remove the red plastic cover. Just bend it up enough to gain access to the battery positive terminal.
    I suggest that the OP remove the brake power supply which is adjacent to the 12V battery. It is not necessary to remove the wiring harness connectors. Just remove the mounting hardware and place the power supply out of the way when removing the 12V battery.
    One difficult step is reinstalling the traction battery vent duct which runs over the 12V battery, without dropping the screw that holds the duct to the fender. It might be useful to have an extendible wand with magnetic tip, to help fish around for any hardware which is dropped into the fender.
  4. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    Oh sunking, please do not misunderstand my response. If that made you feel uncomfortable, I apologise. Reason was you never mentioned your car was all the time taken care by your dealer until this message. Well I have my pre own beauty for three years. It never gave me ANY issue as well. Like yours. Very reliable and made me happy when driving it. Average gas millage is 49. Just changed the electric collant pump per the LSC and also done the transaxle fluid exchange( it runs more smooth and quieter). So did have you done your LSC and fluid exchange( which is our usual practice every 60000 miles.)?
    Continue enjoy you nice baby. Regards.:)
  5. Brutsie
    Brutsie Power User
    What does "MFD" stand for in this context?
  6. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
  7. sunking989
    Levittown, Pa
    OP here...took a trip to my local Toyota dealer to pick up a new 12 volt battery. Got there and was informed that they sold the last two in stock earlier today. They ordered one for me and was told that I could pick it up on Tuesday. So...will be driving my other car for the next couple of days.
    Checked the 12v battery status via the MFD and with just the accessories on it was at 11.9 and when I turned on the headlights, rear defroster and heater it dropped to 10.1.
    The battery will cost me $176. I asked what it would cost for them to install and was told 1 hour at $99 per hour....ummmm, no thanks, I think I will do it myself.
    Update you with progress next week.
  8. sunking989
    Levittown, Pa
    New battery installed. When I picked it up the guy at the parts counter was telling me that it probably isn't the problem. I told him that all of my friends told me I was on the track. So, we will see. I will update you with the latest affter a few days. Keep your fingers crossed.
  9. Oldwolf
    Oldwolf Prius Enthusiast
    826
    110
    NC
    2016 Prius v wagon
    Good thread. Waiting to hear if the new battery fixed the problem. I still have the original battery in my 05. Voltages look good however.
  10. sunking989
    Levittown, Pa
    Hello everyone...OP here!
    Well, it has been three days since I replaced the 12V battery and all was well...until this morning...Went out to start the car and I had the same issue. No indication on the dash that the key is present (either when inserted or just in my pocket). If I let it sit long enough, the car does finally recognize that the key in there and will allow me to start it. I have changed the battery in both of my keys (did that before the 12V battery).
    The 12V battery does not seem to have been the issue even though my voltage readings were right on the border line of being a problem.
    So...what would you suggest I look at next? I hate to get it started and drive it to the dealer and give them the open checkbook to work thru it.
    Any additional suggestions would be greatly appreciated!
  11. Patrick Wong
    18,210
    6,516
    Interesting. It sounds like the immobilizer ECU might be flaky, where it takes some time to recognize that the fob is authorized to start the car.
    If you can easily replicate the problem then I would say it is time to visit the dealer. However if the problem only happens once every three days then when you take the car to the dealer it will probably work great and "no trouble found" along with a repair invoice for one labor hour of the tech's time will be the result.
    These intermittent electrical problems are the worst to have since the root cause is so hard to pin down.
  12. sunking989
    Levittown, Pa
    Hey Patrick,
    Thanks for the response. Unfortunately, the issue cannot be duplicated easily. You mention the "immobilizer ECU". Can you explain what this is/does? Is it something that I can specifically point to at the dealer and ask that they check?
    When I went to the dealer to get the 12V battery, the guy at the parts counter mentioned that with the readings that I was getting on the MFD for the battery that he didn't think that it was the issue. He suggested that the "antenna" that the FOB talks to might be the issue. Is this the immobilizer ECU?
    Thanks again for everyones input!
  13. Oldwolf
    826
    110
    NC
    2016 Prius v wagon
    Interesting. Do the voltages still look to be in the OK range? Maybe a parasitic load is draining the battery?
  14. sunking989
    Levittown, Pa
    Not sure. I left the car home with my wife to drive to work today and she called to tell me. I will check the voltage thru the MFD when I get home from work tonight...if I can get it to start/recoginize the fob :)
  15. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Hey OP,
    Are the brake lights coming on when you try to start the car? If not the switch may need adjustment? My understanding is that the brake switch gives the OK to start? I may be wrong on this, but we should find out soon enough!
    Cheers;
    Hal
  16. joe53
    joe53 New Member
    Massachusetts
    I just changed my auxillary battery in my 2005 Prius which I bought used in October, 2010 with 111K. I used several You Tube Videos made by other Prius owners for assistance. They were very helpful. Make sure that if you do it yourself, you call several Toyota Dealers for prices. I bought mine for $ 138.60. One dealer was telling me that it was $ 346.00. Due Dilligence is required.
  17. Patrick Wong
    18,210
    6,516
    The immobilizer ECU reads the fob's unique ID and verifies that the fob is authorized to start the car.
    Since you say that even when the fob is inserted into the dashboard slot, the car will not start, then the Smart antenna in the car (located in the center console) would not be the issue.
    Another poster suggested that the brake pedal switch might be faulty. If that were the case then you should at least be able to make the car ACC-ON and IG-ON, when pressing the POWER button.
    If nothing happens when you press the POWER button, then the brake pedal switch is not the issue.
    Yes, you could ask that the immobilizer ECU be checked but if the no-start symptom does not exhibit itself when the car is at the dealer then NTF will be noted by the tech and nothing will be done.
  18. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    Just to be clear, there are two ECUs: immobilizer and smart key.
    Please check all 12V battery connections. Often, a loose terminal or loose/high resistance connection of the negative wire to the body will cause trouble.
  19. beam99
    beam99 Junior Member
    uk
    Was there any other jobs done on the car recently, any extras fitted that mite interfere with the electrics of the car?,
    Theres a main relay located under the dash that powers up IG1, 1G2 and MDF etc when you go to start the car, I had a issue with one before where the vehicle was stuck in park and would not power up , And this relay was the problem, Did you get the fault codes checked ?
  20. Hal W
    Hal W New Member
    872
    53
    Must have been a brain fart as OP is not talking!.Hal
