2005 Prius Wiring Harness
Discussion in 'Gen 2 Prius Main Forum' started by hbbird, Apr 30, 2025.
  1. hbbird
    hbbird Junior Member
    24
    Apparently my wiring harness has been chewed by rodents and said wiring harness is keeping my Prius from running. The mechanic at Toyota said a new harness would make things much easier as he is having trouble figuring out what is wrong with the existing wiring harness. And guess what? Toyota doesn't make them any more. I thought I could buy one from ToyotaPartsDeal but what a terrible company. I've been waiting for a week for them to contact me for payment and it turns out they canceled the order because they didn't have the part and never let me know. Now I am trying to find the part at Amayama in Japan and it happens to be a holiday week there.
    On the Amayama site, they are telling me that harness part 82141-47e91 (told to me by my mechanic) does not match my VIN, but instead part number 82111-47191 , 82111-47201 , or 82111-47211 would work better. I have asked my mechanic for the engine number to see if that will help narrow down my choices.
    Any insight on my dilemma would be helpful,
  2. Tombukt2
    Tombukt2 Senior Member
    13,845
    2,515
    Durham NC
    In Tucson Arizona this is going on seriously and some mechanic has traced it down to the underhood engine loom assembly no kidding that's an awful lot of wiring to just blame on the car not running I would think something attached to those wires maybe. Seems like an awfully big reach to me anyway course here I could just go to another car and well have at it and then I'm not sure that all of that's going to go like it seems like it ought to you're going to probably have to have the engine and transmission pretty much out of the assembly to get it all out haven't tried it personally but looks like it'd be quite something especially over there at the fuse box and whatnot like I said it seems like an awful large reach. With the amount of cars that are out and available now it seems like an awful stretch at best.
  3. pasadena_commut
    pasadena_commut Senior Member
    3,038
    942
    Southern California
    Will the car start up enough to let an OBD2 device talk to it? If so you could run Techstream or an equivalent and it should show which modules can communicate and which cannot. From that and the wiring diagram it may be enough to locate the damaged section. Rodent damage to wiring is often pretty obvious, at least if you know where to look, more or less, for that damage.
  4. PriusCamper
    PriusCamper Senior Member
    13,444
    5,428
    Pacific Northwest, USA
    The first problem is talking to a Toyota Stealership in the first place... They're warranty specialists so they only replace the most expensive parts possible to make as much money as possible for the stealership. They probably never even bothered to splice the wires back together because Gen2 Prius has been out of warranty for more than a decade.
    Basically, you have an electrical wiring problem that can be repaired via a normal competent non-stealership mechanic that's willing to pull portions of wiring harnesses from the abundant number of wrecked Prius at wrecking yards.
    Of course as Tom is rambling about above, the diagnosis might NOT be correct. We need to see pictures of the damaged wires to be certain.
    Lastly, if you let us know what region you live in, there might be someone on here who lives near you who would be willing to help you out.
  5. hbbird
    24
    Well, the mechanic said they moved a wire and the engine shut off, which sounds plausible. I know this is difficult because the dash most be torn apart to remove and replace this part. I'm getting a bit old to wrangle with a car at pick-a-part but I'm getting desperate. Would you believe I did an inquiry at Amayama on May 2nd, then had to wait until Golden Week was over in Japan to find out they didn't have it? I asked Google AI and they suggested another harness might be compatible, which I hadn't thought of, but when you call the national parts number you have to give then a dealer number, forcing me to work through the dealer. Which I can do, but I had hoped to avoid it. I'm still wanting to replace the wiring harness, but honestly, I'm tempted to try to get in there and see what I think about the repair. People could make good money pulling good wiring harnesses out of junked Second Generation Priuses.
  6. hbbird
    24
    I live East of Tucson. I think the repair guy is trying to give me a break, because I know they did troubleshooting for some time, but are only charging me for an hour. I will also say I had a front end collision with a deer about a year ago, and I don't know if that messed something out.
  7. hbbird
    24
    I have two OBD devices and couldn't get either one to work. That may be the problem the dealer is having. The OBD devices have worked in the past.
  8. PriusCamper
    13,444
    5,428
    I definitely agree that some diagnosis can take many, many hours if not days or weeks and mechanics do tend to eat some of those costs, especially if the problem turns out to be something super stupid simple...
  9. hbbird
    24
    Maybe the repairguy at the dealership can explain to me better what is happening. I'm pretty sure that the problem was that they plugged it in the analyzer and got nothing. I know it starts up, because I was able to start it up since it broke down. I'm going to think this through some more, and I'll let you folks know what I decided.
  10. Tombukt2
    13,845
    2,515
    Durham NC
    I've a loaded 05 sitting right here I'm getting ready to pull the motor out of it so we'll see I know the harness you posted or one of them was $2,000 so I'm assuming that's the main harness that runs under the hood possibly with the fuse box or I don't know how that's done you just get all the plugs there and you're going to plug them back into your existing plastic fuse box or does this thing come with the new box or my thinking of the wrong harness assembly but some of it looks doable all unplugged laid out push through the hole in the firewall I've done it in Corollas and old supras. So if you were to catch one of these cars on its way in to like LKQ or one of those big junk yards and told them you wanted to get the main engine wiring harness under the hood I wouldn't think that would be a problem you just want to get it like that before people start cutting on it tow lots they may have them too depends on the state you're in how that works
  11. pasadena_commut
    3,038
    942
    Southern California
    If the entire wiring harness was fubar'd the car would not have started. Maybe check the OBD2 with a voltmeter and verify that pin 16 is 12V when the car is on and continue on from there?
    Tombukt2 likes this.
