2005 Prius with 300k miles, DTC c1319 problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JC91006, Dec 29, 2015.
  1. evallded
    evallded Junior Member
    71
    Portland, Or
    JC91006, I am curious if you ever found a solution to this issue and what you did to solve it.
  2. JC91006
    16,933
    8,643
    I don't have that car anymore. But I believe it is a warranty item now. It wasn't warranty when I had the car
  3. evallded
    71
    Portland, Or
    Ok, thank you
  4. Vasiprius
    Vasiprius Junior Member
    Chicago
    Hi there , did the problem reappear ?
    SFO likes this.
  5. Vasiprius
    Chicago
    C1319 ( C0200, C0205) - 166k miles , 2008 ;
    car out of warranty , I was told at dealership it's a $2,700 job to replace the "brake actuator"
    do youguys know if I reset the ABS wit ha paper clip port 4 / 13 can I damage more or is it safe to try ...
    Thanks
  6. Patrick Wong
    18,210
    6,517
    You can try to reset the skid control ECU. An alternative is to purchase a used brake actuator and have that installed by an independent.
  7. Vasiprius
    Chicago
    Hi Patrick,
    Are there any recommended shops here on the forum or mechanics that could help replacing the actuator? Chicago land area.
    I am willing to help, I don't mind getting my hands dirty but I'm afraid this requires more knowledge.
    If you know anybody that can help with this brake actuator, Chicago land area, I would really appreciate it.
    Thank you!
