2005 Prius Won't Go Into Gear
Discussion in 'Gen 2 Prius Main Forum' started by Mark Thompson, Jan 13, 2019.
  1. Mark Thompson
    Mark Thompson SatRocket
    Came back to the car on a cold afternoon. The car appeared to be working correctly, but the "Ready" did not come on and the car would not shift into Drive or Reverse. I tried resetting the car in various ways that I read about online and in Prius chat, but nothing worked. I finally disconnected the battery and reconnected it. That temporarily fix the problem. I was able to get home but upon arriving home and shutting off the vehicle, it would not restart again - same problem. I disconnected the battery a second time and again the vehicle would then operate.
    The red triangle was on both times when the vehicle would not operate. I was able to erase that with a code reader. However the actual error codes do not show up so I'm not sure if there is a problem that is causing the computer to operate faulty or the computer itself is faulty.
    I have had issues several times with the traction battery having bad cells, but that but even though the red triangle came on, it did not adversely affect the operation of the vehicle.
    Hoping to hear from someone who knows how to prevent this, not just fix it...
    52,863
    any warning lights?
    have you read the trouble codes with tech stream?
    have you tested the 12v?
    is there movement in the inverter fluid reservoir?
    how many miles on her?
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Isn't this the "normal" symptoms of a HV Battery ground fault?
    JC91006 likes this.
  4. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Wouldn’t that throw a code that could be read on a cheap OBD scanner? I’m guessing that’s what the guy is using, Techstream would have pulled up a code.
  5. JC91006
    16,936
    8,647
    To prevent this problem (which you'll need to pull the codes and see where it's coming from), you would need to replace the part (my guess is the entire HV Battery).
  6. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    Remove HV battery from car and place on driveway.
    Remove metal covers and pressure wash the battery to remove all 'leaked' electrolyte, therefore clearing ground fault problem.
    Suspend HV battery to allow drip dry, or dry using compressed air or hair dryer.
    Install covers.
    Install in car and fire it up.................
    No guts no glory...........
    Just kidding...please don't do this....
    Christopher Burchell likes this.
  7. Mark Thompson
    I don't know how to read codes with tech stream. Can you instruct me?
    The 12v battery was reading 12.6v, but the vehicle rapidly drains the voltage being "on", but not starting.
    I think my plan is to pull the HV battery and check the cell voltage and replace any bad cells. If that doesn't fix it, maybe Donald Trump will help me fix it...
  8. bisco
    52,863
    good idea, ask him to hold onto the rails after you take the cover off :p
  9. Mark Thompson
    Unfortunately Donald didn't show up to help, guess he's on furlough (wearing an orange jumpsuit).
    I removed the HV battery. No bad cells (all cells in the range 8.01v to 8.09v).
    I think I need to read codes. What is the best way?
  10. dolj
    dolj Senior Member
    8,652
    4,401
    Wellington, New Zealand
    While you have the HV battery out and opened up, inspect every module very closely for signs of leaked electrolyte. It is very hard to spot as it is clear in colour. You could also use your ohmmeter to see if there is any voltage resistance between each positive terminal and the case below it.
  11. LoveourPrius
    LoveourPrius Junior Member
    16
    If the battery is charged then what resistance would you expect to measure between the positive terminal and the case below it? Are you referring to the positive on each battery cell or the full HV battery? If you are referring to the HV battery then how do you tell which one is the positive terminal )I don't think they are marked). Does leaked electrolyte mean there is 1 or more bad cells? I also noticed crystals on top of some cells, so what does that indicate? I've been told there are sensors built into the battery that may be broken and cause the battery to fail. How do I test them?
    #11 LoveourPrius, Aug 28, 2019
  12. dolj
    dolj Senior Member
    8,652
    4,401
    I was only talking about the HV battery and the modules of which it is made (there are 28 of these modules.)
    Probably a poor choice of words, but if you can measure any voltage from the +ve terminal of any module to the case, then you have a ground leak. You could also try to measure resistance, but you need to use a MΩ meter to measure. You should be reading 10 MΩ or above (IIRC).
    No, I am referring to each module. Each module is made up of 6 cells and you cannot do any cell level diagnostics or repair.
    They are.
    It means that there is at least one leaking module, but that does not mean there is only one leaker, there could be more than one.
    That could indicate electrolyte is leaking.
    You have been misinformed or have misunderstood. The sensors measure voltage and temperature and the wire frame harness (as it is called) connects back the battery ECU which monitors the battery.
    Hope that clarifies.
    BTW, if you are just ask to clarify, that is ok, but if you intend to ask about your car specifically, please start your own thread, rather than hijack someone else's. It can make a thread very confusing when there is more than one subject vehicle involved.
    Skibob and SFO like this.
  13. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Not trying to condone such, but someone actually did this on a gen3 battery pack (after removing the important bits first) :
    I hate meeses to pieces!
    Raytheeagle likes this.
  14. Skibob
    2,912
    1,505
    Northern California
    This is the most important thing you said.
  15. LoveourPrius
    16
    I'm new to this so thanks for feedback. I was looking for clarification but now will start a new conversation.
    Skibob likes this.
