2005 Prius won't start after changing headlight
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JSheikhai, Jul 3, 2015.
  1. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Good start. I suggest rooting around the area of the headlight and beyond, and checking every electrical connection you can reach. Also, look at the cables to see if any are torn.
    The VCI cable and software will help you narrow down the area.
  2. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Possibly 12v is OK but there are a few things to know about it to rule it out. The 12v charges very slowly during driving so you really need a good long trip or trickle charge to get to full charge. Did he replace with Toyota OEM Prius battery or what? Then there is the diagostics mode where you can check voltages.
  3. Patrick Wong
    18,210
    6,517
    1. Put a charger on the new 12V battery overnight, to make sure it is fully-charged.
    2. Check the tightness of the cable connections to the battery, including the negative cable connection where it bolts to the body.
    3. Make sure the 12V battery is securely mounted in the battery tray so that it cannot move around as the car hits a bump.
    4. Open up the main relay/fuse box next to the inverter and make sure that all relays and fuses are securely plugged in.
    5. Inspect the dedicated positive jumpstart terminal in that box (covered by the red plastic cover) and make sure the 10 mm nut at that terminal is tight.
    6. Get Mini VCI so that you can retrieve the DTC logged by your car.
    7. If you are not able to find the loose connection then you will need to obtain professional assistance.
    52,760
    or go to a toyota dealer, and pay them $100. to retrieve the code.
  5. JSheikhai
    JSheikhai New Member
    Las Vegas
    I just found the coolant inverter pump connection loose. The inverter wasn't being cooled so the DCDC shut down when it got hot and wouldn't start until it cooled off which it doesn't do often in July in Las Vegas. The inverter pump is right behind the headlight they changed!!
    Patrick Wong likes this.
  6. JC91006
    16,931
    8,640
    Problem solved, a nice letter of complaint should follow
  7. alekska
    alekska Active Member
    435
    138
    Atl
    Sorry I somehow messed up the capacity
    Alex
  8. Patrick Wong
    18,210
    6,517
    It's good that you found this. Have you gone over any bumps since restoring this wiring harness connector - to verify that this was the root cause?
