2005 Prius - won't start. Due to cool weather conditions?
Discussion in 'Gen 2 Prius Main Forum' started by Rms2005, Jan 1, 2018.
  1. Rms2005
    Rms2005 New Member
    Georgia
    I just payed $5000 to replace the hybrid battery and also just replaced the 12v battery as well. The car won't unlock with the key fob (which is charged) and after I manually unlock the car, the dash board is completely black and no lights come on. The car won't start when I put the key fob into the slot. Not sure what is going on and growing more frustrated by the day. Help!
  2. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Empty 12V battery? Check the 12V battery voltage. If 12V battery is empty you need to charge or replace it. You can also just jump start it. But you need to keep the Prius in ready for at least 4 hours to charge the 12V battery.
    You can jump start the Prius from under the hood jump point. Keep the other vehicle turned OFF when jumping Prius and make sure that you connect the cables correctly.
  3. Rms2005
    Rms2005 New Member
    Georgia
    I will check the voltage and get back to you. Thanks for the advice!
    Raytheeagle likes this.
  4. DMC-5180
    DMC-5180 Active Member
    292
    134
    Yeah, this sounds like a classic dead 12v issue. Did you somehow accidentally leave the power on or a door ajar or dome light on overnight?
    You don’t necessarily need a vehicle to jump start if have a battery charger. You can simply connect the charger to the jump start points and let it do its thing for an hour. After that you should be able to power up the car and let the inverter do the rest.
    Also how recent is recent? Yesterday or a month ago? Have you been driving the car without issue since replacement up to this point?
    iPhone X ?
    kenoarto likes this.
  5. kenoarto
    kenoarto Senior Member
    395
    Chicago, IL
    Sounds like a dead 12v.
    BTW: If you paid $5000 for just an HV battery, you got ripped off. That should have been around $3500.
  6. padroo
    padroo Senior Member
    2,763
    2,250
    I only got $3,000 trade in on my 2008 Prius and there wasn't anything wrong with it. Sounds like you should have bought another car. JMHO
  7. kenoarto
    395
    Chicago, IL
    Dealer trade-in's are always bad deals. I would have given you more for your car, just sayin'...
    SFO likes this.
  8. Rms2005
    Rms2005 New Member
    Georgia
    It was 4990$ for the replacement Hybrid Battery and two computer components.
    I just had the Synergy system replaced because it was no longer charging both the hybrid battery and the 12V. But as of two days later (aka today) the dash board lights don't come on when I start the car and the check engine light comes on for a moment at start up. When I put the car in park and was trying to turn it off, it would not cut off and wouldn't loosen the key hold. . Any ideas for what on earth this could be now?!
    Also - thank you all for you feedback! I really really appreciate it! Sorry to be just now responding.
  9. bisco
    48,994
    could be a bad multi info display. gas gauge/speedo/etc. try holding the start button for 4 or 5 seconds.
    Rms2005 likes this.
  10. Rms2005
    Rms2005 New Member
    Georgia
    I have had to do that to get my key out... but that is not normal. I didn't used to do that, but I am finding I am having to do that more often now. I wonder if my 12V needs to be charged or replaced (just replaced it in Dec.)
  11. bisco
    48,994
    thought you were going to check the voltage?
  12. Rms2005
    Rms2005 New Member
    Georgia
    I haven't checked it since I got the car back because everything had been working great. It was in the shop for 2.5 weeks. I just got it back on Tuesday. But I can certainly check it in the morning tomorrow. If it is a good charge, any ideas on what the problem could be?
  13. dolj
    dolj Senior Member
    7,508
    3,773
    Wellington, New Zealand
    You have a failed combination meter (CM). You also have the model of Gen 2 where the combination meter will stop at 299,999 mi.
    See the link in my signature entitled "Combination Meters that stop at 299,999 miles, who's affected and what you can do about it."
    If you choose to let the dealer do the job it will cost you $800 - $1000. If you elect to go the DIY route, it will cost you ~$150. If you can't DIY, get a replacement unit from Matt @Texas Hybrid Batteries and find a local garage to swap it for you. Talk to Matt about your options.
    Prodigyplace and Rms2005 like this.
  14. Rms2005
    Rms2005 New Member
    Georgia
    Another thing is that the steering wheel controls are the only way I can control my heat/AC and radio. The LCD display reads "The external system is not connected". I read on another forum to check all of the cables that are plugged into the Nav system under the drivers seat and they are all intact and plugged in.
  15. dolj
    dolj Senior Member
    7,508
    3,773
    Yes, another symptom that confirms your CM is bad.
    #15 dolj, Jan 25, 2018
    uart and Rms2005 like this.
  16. Rms2005
    Rms2005 New Member
    Georgia
    Woah! Thank you so much! I am a DIY kinda gal so I don't mind trying my hand at it. My car is only at 157000. Is this normal?
  17. dolj
    dolj Senior Member
    7,508
    3,773
    Sadly, it is a common problem, but not too difficult to DIY.
    Further to my previous post, if you let the dealer fix the CM, you will get a new CM that still stops at 299,999 mi.
    SFO and Rms2005 like this.
  18. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    You probably don't drive it enough to put a good change on it. That and you not locking the door with the FOB every time you get out especially in the garage. It will alert you to door ajar. Its a very small battery and will not tolerate the insults you can throw at a big battery like letting it go dead repeatedly. Usually a couple of good deads on the little AGM and its done it will never hold a proper charge again.
    Become involved. Get a volt meter. See what the battery voltage is like in different situations like whats it look like in the am before I start the car. Or put the headlights on without starting the car and see what the standing charge it has...its ability to produce proper voltage under load. Thats the one that doesn't lie and its a free test.
    I've never had a 12 volt battery in my car strand me because I know its a big liability and it will not let it get me. Only takes a few minutes to check it.
  19. Rms2005
    Rms2005 New Member
    Georgia
    Thanks for the feedback. I do drive over 4 hours each day though... but we recently had several VERY cold snaps here in Georgia and so I think it zapped the battery... I don't mind going back to the auto shop I bought it at and having them charge it or having them swap me a new one. It is only a month old.
    SFO and edthefox5 like this.
  20. Rms2005
    Rms2005 New Member
    Georgia
    I see. So much better idea to do it all myself. Especially because we will be installing the same part.
