2005 Prius Won't Unlock / Fob Doesn't Work
Discussion in 'Gen 2 Prius Technical Discussion' started by Zerox92, Nov 11, 2011.
  1. Zerox92
    Zerox92 New Member
    Central IL
    So, yesterday my fob just stopped working out of nowhere. Red light comes on, but none of the buttons work... nothing happens whatsoever. So, for a few times I used the key within the fob to lock/unlock the car. Now, even that key won't work. When I peaked inside my car, I noticed a light flashing that I've never seen before. It looks like a car with a key inside of it, and it's been flashing since last night. I've called three different Toyota dealerships in the area and they were all no help. I've tried changing the battery in my fob, but still nothing happens. Any help would be greatly appreciated!
  2. jroussos
    jroussos Junior Member
    South Florida
    12 volt battery sounds like it is shot if it is original. I just went through this on my 05..
    There is a jumper lug under the hood in the electrical box, driver side near window. Take the cover off the box and you will see a red cap over the jumper point. Jump it to a good car battery for 5 minutes and try to start the car.
    If you are a "CSE" this should be within your skill level. If you are in sales find a " CSE" to help you.
    Jerry, recently retired FMTS
    Edit: just re-read your description and realized you can't get into the car. The mechanical key being able to unlock the door should not be affected by electrical failure. That is strange. Regardless if your 12 v battery is original it is time for a new one once you get into the car.
  3. Zerox92
    Zerox92 New Member
    Central IL
    Thanks, that shed some more light on the situation. I've called three dealerships today and none of them had any idea what to do.
    Problem is, I can't get into my car whatsoever. Anyway I can open my hood otherwise?
  4. richard schumacher
    7,683
    1,066
    United States
    The flashing key light on the dash is completely normal and in fact has been there forever. It would be very weird if you can't get into the car using the mechanical key, but if you can't then your only choice is to call a Toyota dealer's open-and-jump service to jimmy open the door. Then with your trusty voltmeter *before* the guy jump-starts the car, measure the 12V battery voltage. If you are lucky it will be dead (that is, less than about 10V) and the solution will be easy: get jumped and drive to the dealer for a new battery. If the battery reads 12.0 to 12.8 V then there is some deeper problem mostly likely requiring a tow and dealer diagnostics.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    The problem here is that the mechanical key works two ways: 1) It activates the power locks, 2) It will mechanically unlock the driver's door.
    When you use the mechanical key with functioning power locks, a small turn of the key closes an electrical switch, causing the power locks to activate.
    If, however, power is not available, such as having a dead battery, you have to turn the key harder, and pull the door open while holding the key turned. It's not intuitive, but it does work.
    Tom
  6. geminirat
    geminirat Junior Member
    32
    Downriver, Michigan
    Fifteen (15) years later and this happened to me, 2005 Prius. Thanks for your post I got it to unlock...
    donbright likes this.
  7. Samuel Williams Jr
    246
    Dayton NV
    Aww crap, now I gotta try it! And if that works, I'll disconnect the battery and roll down the window ... just in case and try it again. :)
  8. Cometflash
    Cometflash Junior Member
    Colorado
    I had to open my with bad battery before. It almost feels that if the battery is actually close to give up, is worse than if dead.
    Almost like the car knows you have the fob, but there is not enough power to use it.
    I have been able to solve the problem, by simply walking away from the car for a bit of time, and coming back and quickly trying to open with the key.
  9. bisco
    52,848
    i never knew this
