Discussion in 'Gen 2 Prius Main Forum' started by pvandrew, Mar 10, 2013.
  1. pvandrew
    pvandrew Junior Member
    Manhattan, Illinois
    A red triangle with a car and exclamation point on the display. What does this indicate?
  2. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    When is this happening?
  3. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
    it can indicate a lot of things - one of them low of gas
  4. boppo
    boppo Active Member
    799
    139
    Owego, NY
    Need a lot more info from you.
  5. priusgto
    priusgto Active Member
    194
    231
    Northern Arizona
    It's an attention getter!
  6. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    Its a built in reminder from your geometry teacher in High School on the Pythagoras Theory. All you have to do now is solve a2+b2=c2, type the answer in the MFD, and the reminder will go away.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    It means the 12 volt battery in the trunk is below 11 volts under load. Time for a new battery.
