1. blk05prius
    blk05prius New Member
    arkansas
    i have a 2005 Toyota Prius that the air conditioner wont work in. it has Freon in it the compressor wont kick so I did some research and my cooling fans aren't kicking on so I did a by pass test and the cooling fans motor is good they just wont kick on. I just replaced my 2 cooling fan relays and they still wont kick on. the check engine light was on in the car when I got it. it throws the code P1121 coolant valve control. I got the part just got to get it put on. Could this part stop my cooling fans from kicking on or my ac compressor from coming on. any advice would be great. thanks in advance.
    52,789
    what are you reading the codes with?
  3. blk05prius
    arkansas
    the first code p1121 was read with just a basic pocket scanner. then oreillys auto parts store came up with the same one I did then 2 others
    52,789
    you might need tech stream and service manual to nail down the fault.
