2005 Problems
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Graz, Oct 31, 2016.
  1. Graz
    Graz Member
    179
    28
    Hello Everyone,
    I came home late on Saturday Night and went to bed. I tried to take the Prius oout on Sunday and it would not start. I jumped it to get the rear hatch to open. Once I trickle charged the 12 v battery, I was able to get displays. it said I was out of gas, and that my mileage had only dropped to about 43 MPH. There was nearly a tank full of gas on Saturday night. Sunday it was flashing EMPTY. I put 2 gallons in. I was able to get it started. But the Triangle with the Exclamation Point is still lit on the dash.
    1. Did I leave the car ON over night?
    2. Would it use nearly 10 gallons of fuel?
    3. Do you think I can get it started enough to get it to a gas station to fill it. Then get it to the dealer to check out the computers?
    How bad did I screw up. I have 165K miles on it, and I love it.
  2. JC91006
    16,844
    8,612
    You are probably not out of gas. When the 12v battery drains, it has to reset the car's computers when it's charged again. When the gas meter starts flashing, it just means it has not detected the fuel level yet.
    Try making sure the 12v battery is indeed good, if not getting a good reading, replace it. Then just start the car. Let the fuel level redetect itself.
  3. Graz
    Graz Member
    179
    28
    Thank You Sir!
  4. Graz
    Graz Member
    179
    28
    I had some issues finding another yellow top locally. But once I replaced it. I am good as gold. And I have a full tank.
