For Sale 2005 pruis hybrid battery
Discussion in 'Private Sales' started by edw91901*, Aug 3, 2021.
  1. edw91901*
    edw91901* New Member
    28
    paint rock,AL 35764
    Have a hybrid battery trying to sell it good hold charge and just had tesed 2 month ago
  2. JC91006
    16,934
    8,644
    are you in San Diego?
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    How exactly did you have it tested ?
    "Good" can mean a whole range of things, some of them will not be functional under actual use.
  4. edw91901*
    28
    paint rock,AL 35764
    It holds at 14.7v when tested I bought a full dynastic tool for when I had change brake and I run a battery test on it I never had any trouble out of the hybrid battery just trying get money up I run it in a ditch going about 90 and messed up front end so was part it out
  5. sam spade 2
    7,035
    2,804
    2017 Prius c
    Wait ......that sounds like the 12 V battery, NOT the "hybrid" battery.
    AND that voltage measurement can ONLY occur when the car is running, so it is a measure of the charging system and NOT of the battery itself.
    IF......the battery is disconnected and it still reads 14.7, then you need a new meter........or new glasses !! :)
