2005 Radio swap?
Discussion in 'Gen 2 Prius Audio and Electronics' started by art1saf, Jan 6, 2013.
  1. art1saf
    art1saf Junior Member
    I have a base model 2005 Prius, can I swap a base radio from a 2006-9 unit?
  2. jdenenberg
    jdenenberg EE Professor
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I put a base 2006 radio into a base 2004 when the CD player quit. When the newer CD player also failed I installed a Pioneer 33HD (~$250 installed) and it was a significant improvement.
    JeffD
  3. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Moved to the Gen II audio forum from the Prius v audio forum.
  4. art1saf
    Jeff thank you for the reply. The unit you installed, where did the place it in the dash and where you able to use the monitor and steering wheel controls. Arthur
  5. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    They are all backwards compatible. Toyota uses a BEAN network for the multimedia.
  6. art1saf
    Does that mean If I find on for a 2007 Prius base model it will syn with all the parameters needed?
    Thank you, Arthur
  7. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    Any 2004 through 2009 will work, nav or not. But be warned that after 2006, the vehicles without the backup camera had lower resolution screens. So 2004-2005 will work. 2006-2009 will work if it has/doesn't-have a backup camera like your car.
  8. art1saf
    Thank you,
  9. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    I edited above. Make sure to select one with backup camera if you have one. If you do not, then either will work.
    This is based off of the part numbers and looking at the wiring diagrams. There may be additional caveats of course. However I have seen swapped units and they do work.
  10. art1saf
    Thanks !
  11. jdenenberg
    3,837
    1,828
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The radio was installed where the OE one was with a Prius specific escutcheon (There is now a small storage slot beneath the radio itself). For another $100 for an interface, the steering wheel controls would work. The MFD no longer controls the stereo, but the Pioneer has a remote control and has lots of buttons.
    JeffD
  12. art1saf
    Thank you Jeff, If you ever get a chance to post photos I and others would like to see the finished product.
  13. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    746
    Delaware
    [​IMG]aftermarket is the way to go if you want better sound, aux, usb, bluetooth, etc.
    metra axxess unit allows use of steering wheel buttons. scosche makes a cheesy mounting kit, and adapter harnesses.
    the jbl system is pretty good imho, but would be a major pita to install in a base model.
