2005 Radio w/o nav or bluetooth replacement
Discussion in 'Gen 2 Prius Audio and Electronics' started by Logan Jensen, May 17, 2020.
  1. Logan Jensen
    Logan Jensen Junior Member
    Orem UT
    I've tried searching for this, but haven't found the thread I'm looking more. I'm looking to replace my stock 2005 radio with a new one with Bluetooth, and preferably navigation as well. What's the best radios out there to do that while keeping the mpg tracking and steering wheel controls?
    Sean2005Gen2CA likes this.
  2. Sean2005Gen2CA
    45
    32
    I'm in the same boat, it'd be great to see a list (or just a few options) of successfully installed head-units that are compatible with the steering wheel controls! I see several other posts in this forum about Crutchfield custom harness adapters that match any system to your vehicle, does that mean technically that any stereo could potentially be installed, as long as the dimensions align?
  3. Berch1943
    Berch1943 Member
    146
    Arizona
    I'm wondering too could you replace the stock MFD with another stock one that has navigation & bluetooth in it? Like this
  4. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    744
    Delaware
    crutchfield will hook you up with everything you need, and they give good instructions too. your steering wheel buttons will work if you get the right stuff. they can help you with all that.
  5. Tomahawk297
    Tomahawk297 Junior Member
    Mississippi
    The Alpine ILX-W650 is an amazing little head unit for $300 with apple and android play capabilities, the touch screen is extremely responsive (they use the same technology in the touch screen as your phone has), and Crutchfield can hook you up with the whole dash kit, wiring, and adapter to keep the steering wheel controls for I think it was $90. After tax you’re all in for about $420. Hit up Crutchfield!
