2005 Rear hatch rattle
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Paul Schenck, Nov 1, 2017.
  1. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    My 2005 has a noisy rear hatch, I’ve removed all the plastic trim attempting to locate it but thought I would post and see if any of the wizards here had dealt with this problem?
    iPhone ?
    52,848
    iirc, some have had something come loose inside the hatch door itself.
    jerrymildred and Paul Schenck like this.
  3. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    My brother wedged a piece of napkin between the plastic trim and the metal. Worked like a charm.
    Later on I wanted to explore the hatch innards to install a back up camera. When I reinstalled everything, I realized one of the trim fasteners wasn't attached. No more napkin needed.
    Raytheeagle and Data Daedalus like this.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Could be that one of the clips holding various wires and cables broke its mounting tab. There are several in there, iirc.
    Data Daedalus likes this.
  5. LoopM
    LoopM Junior Member
    Hood River, OR
    For me, the fix was to clean and lube the latch in the floor that the hatch closes into. If I rode in the back while the rattling was occurring, pressing up on the hatch would make the rattle stop. It took me forever to figure out how to fix it, and there was nothing I found on PriusChat. I was watching a video on fixing door latches on a Sprinter van (my other vehicle) when the idea hit me.
    Here's what I did:
    1. Pull the plastic cover off from the latch in the floor
    2. Spray some WD40 to clean the latch mechanism
    3. Wipe off the dirt
    4. Lube with a lubricant such as oil, silicone, graphite, etc. (Traditional WD40 is not a real lubricant.)
    5. Work the latch back and forth with your finger to close it, then press the hatch release button on the exterior of the hatch itself to release it. Repeat as necessary.
    The rattle might come back after a few days. If so, repeat the procedure and the rattle should be fixed for a few years hopefully.
