2005 Red warning light - code P0AA6 - 526 & 612 also P0300, 301, 303
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Paul ter Brugge, Dec 24, 2014.
  1. John Gjata
    John Gjata Junior Member
    27
    San Diego
    Thanks
  2. Cody26
    Cody26 Junior Member
    86
    Raleigh, North Carolina
    I also ordered a megohmmeter and I will see what can I do from there.
  3. Cody26
    86
    What I have learned is that you can simply measure the voltage to identify if there is any voltage leak in the pack. Myself, I was gonna open up the pack and use megohmmeter to measure the leaks. But the below video claims that we don't need to do that to find out whether there was a leak. Watch the video in the link
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Waste of $$$.
    Put your time into a battery physical investigation. You wont be disappointed.
    Take the battery pack out take the covers off and you will find alot of corrosion and in your case a cracked module or 2 with leaking electrolyte.
    Cody26 likes this.
  5. strawbrad
    953
    1,007
    Yes,
    This works and is the easy way to find a battery leak. The video shows about the most careless way to do it. You should wear gloves, don't touch the body of the car, and hold both test leads with one hand. There is no good reason to use two hands and introduce the possibility of voltage across your heart. I prefer to measure at the negative and positive terminals on the battery side of the relays. You can tell how far away the leak is from the point of measure from the level of voltage that does not bleed off.
    Cody26 likes this.
  6. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    I like your way since it is easy to hold both leads in one hand at that measurement location.
