2005 sat for 1 year help getting powered back up
Discussion in 'Gen 2 Prius Main Forum' started by Jimmie Ray, Oct 1, 2017.
  1. Jimmie Ray
    Jimmie Ray Junior Member
    33
    Hi folks. Just bought a 2005 Prius from a good friend. It’s totally loaded with leather HID headlights, Bluetooth, navigation all the bells and whistles. Beautiful car. MY friend bought brand new for nearly 40K. It’s been maintained well it’s whole life. Has 165K miles. It sat for a year in her garage. I bought it today and trailered it Home. Bought a new 12V battery and will install tomorrow. What do I do next ? I only paid 2K for it. She gave me a pretty good deal.
    Aaron Vitolins likes this.
    52,641
    congrats and welcome!
    change the oil? drain the gas? charge the hybrid battery?
    any way to get the maintenance records to see what needs to be done?
    never heard of a 2005 prius going for 40k.(n)
  3. Jimmie Ray
    33
    When she bought the car it was 40k New
  4. Jimmie Ray
    33
    Thanks for the welcome. The car only has 2 bars of gas in it. Should I still drain it. We jumped the car off today and it only ran on the old battery for a few mins. The it stopped. The old 12v was just too flat. So I bought a new one tonight and will install it tomorrow. Should I still Fran the gas or just fill up with fresh gas. I will have the oil changed once I get the car driving. I live in an apartment so I can’t ch it myself.
  5. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    If that is truly what she paid, the dealership is probably still talking about the whale they landed that day. o_O
    jerrymildred likes this.
  6. frodoz737
    frodoz737 Top Wrench
    4,763
    2,539
    33
    Thoroughly inspect the vehicle inside and out, giving additional attention for evidence of rodents. Change ALL fluids/filters and flush the brake system.
    Jimmie Ray likes this.
  7. bisco
    52,641
    hard to say, but a year can be hard on gas. you could try filling it, and if no go, then drain it.
  8. Jimmie Ray
    33
    So just put the new 12v in the car in the morning and press the power button? The car should fire right up after sitting for a year?
  9. fotomoto
    5,639
    3,815
    So. Texas
    Most likely the car didn't really start. What it did was try to spin (crank) the engine with the HV(high voltage) battery which is most likely nearly discharged. It spins at a high enough RPM that it sounds like it's running but it's not. Continuing to do this can be very bad for the HV battery.
  10. bisco
    52,641
    not likely, but possible. more likely the hybrid battery will need to be replaced.
  11. Jimmie Ray
    33
    You know. You’re probably right. I think there was biding war on this car at the Naples Florida dealership. IDK
  12. bisco
    52,641
    possibly. they were hard to come by, and southeast toyota is a known gouger.
  13. frodoz737
    4,763
    2,539
    33
    Agree...the traction battery may be an issue. That's 12 years followed by 1 year static. It's all speculation though until you fire it up and see.
  14. frodoz737
    4,763
    2,539
    33
    They were all gougers back then. Gulf States wanted 3-4K over.
  15. Jimmie Ray
    33
    So what do i do? Put in the new 12v Andrew press power?
  16. frodoz737
    4,763
    2,539
    33
    "After" you thoroughly inspect it. Replace your FOB batteries too. Foot on brake pedal, press power and release, release pedal.
  17. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    Why did the Prius sit for a year? Where in FL are you located?
    Keep us posted (y).
  18. Jimmie Ray
    33
    Ok. Will do. I have 2 FOBS one works the other will need a new battery. We did look over the car a little today. It was in her garage and did not appear to be any rodents. But I’ll look again. So if I replace the battery to the fob that is flat will i have to reprogram it too ?
  19. Jimmie Ray
    33
    She bought a new car and decided to sell the Prius recently. She did run the car a few times in the year. So I guess that’s good. I’m in Brooksville
    bisco and Raytheeagle like this.
  20. frodoz737
    4,763
    2,539
    33
    No reprogramming required if original.
