2005 sat for 1 year help getting powered back up
Discussion in 'Gen 2 Prius Main Forum' started by Jimmie Ray, Oct 1, 2017.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Could be good or bad. Depending on how long she ran it for, it might not have done enough to keep the HV battery charged up.
    What I would do if unsure would be to keep it on the trailer and go 50 miles south to Tampa where @TampaPrius.com has a shop and he can help sort you out;).
    Hope that helps(y).
    jerrymildred and Jimmie Ray like this.
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    OK, that's better. You'll need to get up to speed on how a hybrid powertrain performs. Your statement that the engine (ICE) ran for "a few minutes" may mean it's performing to spec. because after the ICE warms up (doesn't take too long in Florida this time of year) it stops till needed again (various reasons).
    Letting an older HV battery sit is very bad and I wouldn't be surprised if you get trouble lights (codes) once you replace the 12v and start driving it.
  3. Jimmie Ray
    Jimmie Ray Junior Member
    33
    Thanks a lot everyone. I will update you all tomorrow. Is there an app for this chat on smartphone?
  4. JC91006
    16,930
    8,640
    1. This is a hybrid, the engine will stop after it warms up.
    2. The high voltage battery maybe out of balance after sitting 1 year.
    3. Definitely replace the 12v now so you won't run into problems with it later
    Jimmie Ray likes this.
  5. Jimmie Ray
    33
    Thanks. I’m replacing it in the morning. Praying I do not have to replace the HV pack. Will the gas ⛽️ engine start if the HV pack is completely flat?
  6. JC91006
    16,930
    8,640
    It should start, the hv battery won't be completely flat. But be prepared to buy another battery real soon.
    If it were my car, I wouldn't start it without charging up the hv battery and balancing it. @fotomoto is selling a charger for half price right now.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Jump on Fotos deal. He's a good guy. It's an outboard hybrid battery charger that will charge the hybrid battery pack to 100% charge.your going to need that anyway unless you plan on buying a new hybrid battery right away which is about $3500. Or a whack a mole repair job on it.
  8. Jimmie Ray
    33
    So I put a fresh 12v in today and the car started two times then shut down. Large red triangle and “problem “ flash on the navigation screen.
  9. bisco
    52,757
    yep, you've got your work cut out for you.
    get a mini vci on amazon and read the trouble codes.
  10. Jimmie Ray
    33
    I give up. I’m calling a company to come over and service the car at my home.
  11. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Would try @TampaPrius.com before dropping money on a drive-by wack-a-mole battery, and then losing your original battery core.
    jerrymildred and Raytheeagle like this.
  12. Jimmie Ray
    33
    I’m going to call him in the morning. I just bought the car . A lot of opinions on what to do. DIY, mobile service , replace whole pack , replace just bad cells ??? My head is spinning. I don’t want to make the wrong decision.
    Raytheeagle and SFO like this.
  13. bisco
    52,757
    the only right decision is new. anything else is iffy at best. there's no such thing as magic.
    edthefox5 likes this.
  14. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Best thing to do is sleep it off to clear your mind, then call Todd as he will give you an informed opinion for your situation.
    He'll get you sorted out(y)
  15. Jimmie Ray
    33
    New like brand new ?
  16. bisco
    52,757
    yes, from a dealer, or if tamper hybrids can supply one. anything rebuilt is just a bunch of old mof=dules waiting to go south again.
  17. Jimmie Ray
    33
    Ever hear of green bean battery replacement ? It’s $1295 with a five year warranty???? Any thoughts. They come to your home and replace it. Everything is included.
  18. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    We have but the modules in the battery you get even though warrantied for 5 years will not last that long. If you go this route, expect to have some down periods waiting on repairs to the battery.
    Call Todd tomorrow before you set anything else up.
    He just hooked @jerrymildred up with 2015 modules for his 2007. Probably for close to what Green Bean is charging.
  19. bisco
    52,757
    what if you call them when it dies, and they don't respond?(n)
    Jimmie Ray and Raytheeagle like this.
  20. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    This reconditioned battery only has an 18 month warranty, the other 3.5 years is 'prorated'.
    Does this five (5) year warranty include all of the R&R (labor) or only the HV battery?
    Will they cover a warranty claim anywhere you happen to be, meaning within their service area?
    Couldn't find a physical address for this business, just located in Apex NC 27502.. where would you go if no one was answering your calls?
    edit: spelling
    #40 SFO, Oct 2, 2017
