2005 SKS component location & wiring diagrams
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Beachbummm, Sep 20, 2015.
Tags:
  1. Beachbummm
    Beachbummm Senior Member
    1,160
    393
    I might try to tackle my 2005's SKS problems before I sell her..
    non of the door handle black buttons work,
    the fob must be inserted into the dash for the car to turn on,
    doors do not unlock when I approach the car with the fob in my hand,
    no response to the fob buttons being pressed but the red LED does come on, fresh battery in fob,
    all fuses are good, all other options are working.
    no error codes
    same reaction when the switch under the steering wheel is pressed (NOTHING).
    Id like to know what components could cause this and where they are located before ripping the car apart.
    Maybe a wiring diagram so I can follow the correct harness..
    Thanks :cool:
  2. JC91006
    16,939
    8,647
    Do you have a working spare key? Has your key ever worked properly?
    valde3 likes this.
  3. valde3
    valde3 Senior Member
    2,002
    751
    Finland
    It just sounds as non-working fob. System (in the fob) that car uses when fob is in the slot is totally separated from the keyless functions.
