2005 smartkey
Discussion in 'Gen 2 Prius Audio and Electronics' started by bigmamou, Apr 6, 2018.
  1. bigmamou
    bigmamou Junior Member
    port townsend, wa
    My Gen 2 sat for a month and a half while the hybrid battery was refurbed. My electronic key now will not unlock the doors and I have to use the physical key although it will lock the doors some of the time. My owners manual and google search tells me about a grouping of 3 switches under the steering column to turn the key back on (as pictured in the manual) BUT that panel has NO switches, only plugs. Any other way to activate the key?
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    That panel button is to turn on/off the Smart Key System (SKS) feature for those cars that have it. First things to check: condition of the 12v battery and the cr2032 battery in the key FOB.
    GOOD LUCK!
    jerrymildred likes this.
    52,863
    12 volt. Charge it up or replace it.
  4. Beachbummm
    Beachbummm Senior Member
    1,160
    393
    it took a month and a half to refurb the battery?
    replace the fob battery and have the 12 volt load tested.
