2005 still using OEM HV battery, replace now?
Discussion in 'Gen 2 Prius Main Forum' started by tangerino, Jun 5, 2021.
  1. Calimobber
    Calimobber Member
    94
    83
    Death Valley
    If you want to go cheap you can swap out the bad ones and keep going. Its not going to get you another 200k miles but it might last a decent amount of time. If you dont want to deal with swapping again or dealing with this in 6months or more then just get new. Either way is an easy fix and sounds like you have watched the videos and seem confident.
    No one really knows how long it would last if you swap, maybe it keeps going for a few years ....
    Keep us updated on your progress :)
    tangerino likes this.
  2. dolj
    dolj Senior Member
    8,646
    4,398
    Wellington, New Zealand
    Why start a new thread? This is the OP's thread.
    I agree with Callimobber, if you wanted to give the quick and dirty a shot, then your data shows pretty definitively that one or both of the modules in block 6 is a problem.
    If one or both of the modules are 1.2 V (or more) lower than the voltage of the modules in the other 13 blocks change it (or them) out.
    The trick here is to find a replacement module that charges and discharges like the others in the other 13 blocks.
    As Callimobber said, "If you don't want to deal with swapping again or dealing with this in 6 months or more then just get new."
    Good luck.
    Samuel Williams Jr likes this.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,015
    NJ-USA
    A "good" module should have a voltage that's the same as all the others in the pack- within 0.2-.3V. The actual voltage values change all the time as the battery is used.
    You may want to just try replacing a couple modules BUT that has a very very small chance of working. The battery ecu looks at the block voltages and if it sees a voltage difference above around 0.3V for long enough time, then eventually it will flag a code. I assume that if the voltage difference is higher, then it takes less time to code.
    The problem is that whatever modules you get would have to be almost exactly the same condition (both capacity and state of charge) as your present modules. Most replacements are "stronger" so the voltage for that block is higher under load. The ecu sees the newcomer as the highest, and now whatever block is lowest gets a code (even if it's only 0.1V lower than all the other "oldtimers"). Replace THAT one and the next lowest (maybe it's 0.15V lower) gets the next code. And so on.
    It's called "whack a mole" on this forum, and some people get a few weeks or months before it happens again, some don't make it around the block.
    If you want a reliable (10 year) repair then new from Toyota-OE (or Newpriusbatteries- aftermarket) are the only choice.
  4. John Dadmun
    John Dadmun Junior Member
    52
    New Hampshire, USA
    Tangerino my novice level 2 cents - haven't seen red triangle or performance degradation but got an aftermarket HV battery anyhow for my 2009.
    The eventual option of nesting hot new modules with others already tapped from 13+ years of hard service, I don't see those aging modules as being worthy of the investment in the new. It would still be a tired old battery with one foot in the recycling bin.
    As the years stack up on these batteries their probability of failure also rises regardless of a few modules having been swapped out.
  5. drone13
    drone13 Active Member
    140
    115
    SoCal
    That sux to have happened so quickly. After you either repair or replace with new or reconditioned, you'll find the battery has been telling you was tired for quite a while. I just went through something similar, but never got a code or RTOD. I did notice very steep grades were draining the battery quickly and the engine was coming on more frequently and reving higher and higher as time went on. None of this manifested during cooler weather, just when it started getting hot. I got a new aftermarket pack and the difference is really surprising... in a very good way.
    As to how you approach this depends on you. If you like tinkering and can spend a week or two with the car down for balancing, and are willing to invest in chargers and dischargers (they don't have to be Prolong expensive) then replacing modules sounds like a great project. Just be aware that your knowledge level of the process will have a great deal to with the likelihood of your success. Whack-a-mole is a very popular game for some Prius owners, and the replayablity is very good since it's likely you will do that more than once. You can generally tell a pro whack-a-mole player because the rear upholstery and body braces to the battery pack aren't installed. But these are the pro players ;) Maybe we'll see this emerge as a new E Sport.
    If you just want reliability and good performance, new batteries whether from the dealer or New Prius Batteries (and soon Jack's lithium modules) are a great way to give your car a new lease on life... if you intend to keep the car. If you aren't committed to owning the car long term then that would be a tougher choice I guess and I would then tend toward a recon rather than new. Keep in mind that because of the drastic increase in gas prices over the last 9 months, even old Prius cars are now selling for higher than they did 6 months ago. At least that's true here in SoCal for the Gen 2 market and gas ain't getting cheaper anytime soon I think.
    So just prioritize based on all the above and decide what you want out of the car and that will lead you to a pretty obvious conclusion of which way to go. Of course, a lot will depend on the condition or the rest of the car. If it has other known expensive repairs you know you will need, that is important in your decision.
    Good luck!
  6. tangerino
    tangerino Junior Member
    82
    16
    WA
    Thanks for all the input! I watched a few battery rebuild videos and figured I might as well give it a shot taking the battery apart. Not too bad overall, hardest part(s) were:
    1) removing the driver-side trim piece. The long bolt was recessed too far to actually reach with a socket+extension, and the trim wouldn't push in far enough to allow access. So I just ended up bending the trim back to expose the two bracket bolts underneath. Removing the trim doesn't otherwise seem necessary.
    2) unbolting the bus bar(?) covering the two main terminals. I bent the bracket there pretty badly trying to get enough torque on the corroded bolt (even with WD40 it was pretty tight); hopefully I didn't do any permanent damage there.
    3) actually lifting the pack out of the car (need to work on my deadlift). a moving blanket helped a lot.
    Once inside the pack, I took half of the bus bars off and checked blocks 1-8. They all had a voltage of 7.83V-7.86V (very nicely balanced, and serials indicate they're all the same age) with one obvious outlier in module 6 reading 6.60V (assuming a dead 1.2V cell inside that module, out of the 6 cells per module?). So I'm going to try replacing that one with a reconditioned one from 2ndlifebattery.com. I'll try discharging my replacement down to ~7.8V (sounds like I can use a lamp socket like this?) to at least start it off at the same voltage as the others; hope it can also discharge similarly.
    I'm hoping the new module buys me a few months while I figure out a longer-term option. I'd like to keep the car maybe 3-4 years but not 8-10, so getting my pack properly reconditioned through a few cycles seems like a nice middle ground compared to a full pack replacement for $1500-2000. Installing a charging harness then hooking up a grid charger seems simple enough at this point. Prolong seemed too pricey so I'd love to know what cheaper options are out there. Just started following: Build Hybrid Battery Maintenance Gear For Under $100 | PriusChat
    Not sure how well reconditioning will turn out with the new module, I'll have to read up more on the wiki and the repair guide:
    Prius High Voltage Battery Reconditioning | PriusChat
    Prius Traction battery repair summery | PriusChat
    OEM isn't as appealing after I found out the parts warranty is only 1 year if I self-install (so it may not recoup that much in the resale value)
    (I may very well become a whack-a-moler; this has been a pretty interesting project so far. I already had my rear seats out for camping :) I may even swap block 6 and block 1 to make it easier to access from the edges next time, thinking this mismatched pair is likely to go next. I also recorded a bunch of Dr. Prius data that might help me predict the next worst blocks. Looks like #4 is next weakest, distantly followed by #13, #1, #14)
    @drone13 Funny you mention the body braces - I was curious whether I'd be safe to test drive the car without putting all the bolts for those back in. Definitely should invest in an impact wrench and a in-lb torque wrench to get the torque right when I put the pack back together.
    With used car prices as they are (I saw a 2nd gen Prius like mine going for $8900 on eBay, almost double what I thought mine was worth), it's easier to justify going the long route :)
    #26 tangerino, Jun 22, 2021
    John Dadmun and drone13 like this.
  7. tangerino
    82
    16
    WA
    Some photos of the bracket over the main terminals that I bent up badly. There was a thinner piece underneath I almost broke, hopefully nothing important IMG_20210621_193829977.jpeg IMG_20210621_200547909.jpeg
  8. drone13
    140
    115
    SoCal
    There's nothing wrong with giving a module replacement a try. It might buy you time to wait to see how Jack's lithium batteries do in the hands of users. And maybe that's all you will need for a long while. At the very least it will give you great experience working with the HV battery and it will be a low cost repair attempt.
    Not too late to get a great deal on an impact wrench. Home Depot still has their Ryobi Days sale going on. They have a deal right now for 2 4AH batteries, charger, and a free tool to go with it for $99. These are Ryobi 18V lithium and are very good. The batteries are the One+ type so they will work in most Ryobi tools if you decide to get some other tools later. I purchased this with the 1/4" impact gun as the free tool and did my HV pack change with it just 2 days ago. I highly recommend this to make your job a lot easier.
    Make sure to either purchase a in/lb torque wrench or check a local auto parts store. Many auto parts store will loan you specialty tools like torque wrenches and they may have one available to borrow. Using a torque wrench is pretty important when reassembling the pack to make sure you get the batteries tight enough so it won't loosen with vibration over time, but not so tight you break off the bolt. I have 1/2" drive and 3/8" drive torque wrenches which won't work for this, so I purchased a Kobalt (Lowe's brand) 1/4" drive torque wrench. It wasn't really cheap at $49, but it is a decent tool to have in the box and I wanted to do the pack change right so I don't have to do it again.
    For the bent parts, don't sweat it. It's just cheap sheet metal and you can easily bend everything back into place. Not a big deal. And yes you can test drive the car without the side body braces if you want, just be careful. You wouldn't want to get in an accident without that support. Just make sure the pack is bolted down, especially the black bolt that is the pack ground bolt.
  9. tangerino
    82
    16
    WA
    Ah that Ryobi deal sounded promising but it looks like they only offer an impact driver, not an impact wrench: https://www.ryobitools.com/ryobidaysfreetool
    I do have a Harbor Freight impact driver that worked okay with a bit-socket adapter (as long as I started the bolts by hand) up until I lost the adapter under the seats :facepalm: Once I can get to HF again I'll probably buy a proper impact wrench there.
    Autozone has a nice $15 torque wrench that can do 0-150 in-lbs, so I'll be using that to put my pack together. It doesn't go high enough to torque the compression bolts though; does those need to be exact? I figure since they don't directly fasten any electrical connections it should be okay.
  10. drone13
    140
    115
    SoCal
    Yep. Impact driver, and it works perfectly for a pack change. It's what I used and the 4AH battery did the whole job with less than 1/2 the battery used. But use whatever you have that will get the job done. Hand tools are fine, but a power tool gets it done with a lot less effort and time.
    I can't really say about the compression bolts since a torque spec is not required with the NPB. Maybe someone who works with original modules can answer that. For the 1/4" torque wrench try it on the old module you're removing to make sure it works ok and doesn't over torque the module bolts just to be safe. It should work ok, but a test on something you don't care about first.
    tangerino and John Dadmun like this.
  11. tangerino
    82
    16
    WA
    Finally got to load test all the modules plus my replacement last night (used Prolong instructions, 120s with my ~50W H4 bulb). Most dropped around -0.34-0.38V from 7.75V but there were a few outliers. Worst one was -0.42V and a pair of -0.40V.
    The weakest ones are mostly towards the middle of the block so I'm thinking about moving them to the (fan) end so they're less likely to overheat.
    I'm also thinking of separating the two weak blocks so the whole block isn't weak, or would that be counterproductive? Is it better to keep similar-discharging modules paired up, even if that means two weak blocks together? Sounds like there are multiple schools of thought on this: Prius Hybrid Battery Recondition Guide | PriusChat
    I'm a bit worried about having this really strong new module (<-0.3V on load test) paired up with an aging module (-0.37V). Should I try to pair the new one against one of my stronger modules (-0.33V)?
    Maybe I'm overthinking this and should either get these reconditioned to revive the weak modules (or replace them outright while I have the pack open?) and let a few charging cycles on a grid charger/discharger balance these out naturally?
    #31 tangerino, Jun 27, 2021
  12. Kristenbluefin
    Kristenbluefin Junior Member
    29
    22
    Indiana
    Sounds almost exactly like how mine went out a couple years ago. Fan got really loud once, then a few weeks later some stutter on acceleration followed in the next couple days by driving home from work at about 20 mph top speed with the triangle. I got a 2012 pack put in and no more issues yet. I'm under warranty till Sept so if anything is going to happen I hope it's soon.
  13. tangerino
    82
    16
    WA
  14. tangerino
    82
    16
    WA
    Also curious, does a module need to compressed just for discharging? I'd like to run a quick 120s load test (with 50W halogen) to make sure my replacement modules are good before installing them in the pack. My impression from reading around is that *charging* the modules is liable to cause them to bulge and become unusable.
    On that note, I have one replacement module that's slightly lower voltage than the others (-0.1V) but not necessarily discharging worse. I'm thinking of charging it up briefly with a 3A Everstart "smart" charger (from Walmart) that has a 6V mode and doing another load test to be sure. It's one of these: EverStart 3A Portable Smart Battery Charger and Maintainer with Digital Display - Walmart.com - Walmart.com https://g.co/kgs/TsC3Sv
    Bad idea? I'd rather not have to discharge all the other modules to bring them all down to match. 3A also doesn't seem too aggressive compared to the other chargers I've seen on here. If it works it would be nice to keep my spare modules charged in case I need to whack-a-mole again.
    EDIT: nvm, I decided to replace the weakest one and discharge the others to match. Got within 0.08v, hope that's good enough. I now have two spare modules I guess I'll just resell or give away
    #34 tangerino, Jul 9, 2021
  15. Kristenbluefin
    29
    22
    Indiana
    Yeah, from a local shop that specializes in prius repairs. 2012 is what they found at the time, don't think they just have them in stock. I'm sure it was pulled from a car that for some other reason was a total loss. But yeah it came with a year and I think I paid a couple hundred extra to add the other two. If I'd had an issue I think they just provide a loaner battery while the re balance mine.
    They are local to indiana but I think they travel to other nearby states in some cases. Was called hybrid and ev repair, I think they have side changed the name to motorcells.
    MOTORCELLS™ - Renewed Hybrid Batteries &amp; Mobile Installation Service
    I'd recommend them to anyone local. If my battery wasn't already so old I'd have just had them renew it, they warranty that too and will keep you running.
  16. tangerino
    82
    16
    WA
    So the pack is back in the car with 3 replacement modules and did a few short trips without problems.
    Voltage difference around 0.2V but isn't peaking anywhere near 1V like before. Biggest concern I see is that IR slowly rose up to 30 on the same block that went bad before. Hopefully that's not going to trigger a red triangle and the voltage will stay in balance.
    Any ideas on why the high IR? Block 6 has the strongest of the new modules from my load tests. Maybe the other module in block 6 went bad after being paired with the failing module? It tested fine in load tests though.
    IR was also high with a block I didn't touch (#4) so it's probably something else. I did torque the bus bar nuts to 50 inlb and removed corrosion with vinegar (but didn't use Ox Gard grease, still bare copper bus bars) Screenshot_20210711-184709.jpeg
    They're all fairly high compared to before, maybe a reconditioning would help?
    #36 tangerino, Jul 11, 2021
  17. tangerino
    82
    16
    WA
    So the battery is definitely running hotter than before, got close to 125F today. The odd thing is it actually got hotter just sitting parked for an hour, from 110 to 120 when I started it back up. Ambient temp is only 80 and temp rose even after sunset so I don't think it's just a hot cabin.
    Fortunately it hasn't hit 130F to trigger a code, but I definitely don't want to run it like this long term. In my testing before this I was usually below 100F. Any ideas what's wrong? I could double-check the torque on my bus bar nuts ( and replace the bars with nickel ones), on the off chance the connections are not as good as before and generating more heat, but I thought I was pretty careful on this. Maybe I should have used ox gard. Or maybe my torque wrench wasn't well calibrated. Or I soaked the bus bar nuts too long in vinegar/salt (overnight) and damaged the threads? They darkened but seemed fine enough to use
    I also double checked the fan inlet isn't blocked and felt a faint intake of air there. The fan is working and I cleaned it before reassembling. Don't think I damaged it. Upper and lower air ducts fit snugly (foam wasn't perfect but not sure that would matter) and weren't cracked.
    Hopefully I haven't borked my cooling system somehow. Screenshot_20210712-212257.jpeg Screenshot_20210712-181139.jpeg
    The other odd thing is that the internal resistance isn't actually correlating with the temperature like I thought. This morning temps were low but IR was still high (30) but slowly went down as I drove and temps went up. Curious how Dr Prius computes IR .
    #37 tangerino, Jul 13, 2021
  18. Sonic_TH
    Sonic_TH Active Member
    575
    96
    Puerto Rico
    2016 Prius c
    Any updates on this? how is the repaired hybrid battery pack doing?
  19. tangerino
    82
    16
    WA
    It's been about 8 months and so far so good. Not sure exactly why it's held up well, but the replacement cells seemed to be very good quality. I'm hoping it can get to one year and then I'll re-evaluate.
    My OBD2 port seems to be malfunctioning or else I could report on some hard numbers from Dr. Prius app. But the module voltage difference seemed to be ~1.1V last I checked, still pretty good.
    Unrelated: my MFD has been flaking out so I guess that's one more thing to fix soon :/
    bisco and PriusCamper like this.
  20. tangerino
    82
    16
    WA
    So yesterday after about 9 months, I got "Problem" from the MFD followed by a red triangle and two hybrid codes (Pack deterioration, don't remember the other). I was able to clear them and drive home without issue (no limp mode and hesitation like last time); car drove fine with no codes coming back after ~30 mins.
    It seems my ECU alerted me a bit earlier than last time; I wonder if I may still be able to drive normally a little longer while I figure things out.
    Haven't been able to get Dr Prius module readings yet; my Viecar OBD2 reader has trouble connecting and when it does there is no data (recommended here Hybrid battery diagnostic and repair tool for Toyota and Lexus). Will probably replace that then gather some data first from Dr Prius and decide what to do. Seeing three options:
    1) I could open the pack up and replace any more obviously bad modules to buy another 6-9 months. Troublesome but the bad module I last remember seeing was the last in the series so that might help some.
    2) Trying a reconditioning charger? Maybe some cycling could help bring the modules in alignment a bit longer. Maybe wishful thinking at this point though.
    3) Best option is probably to just put the $1950 OEM pack in there. But pricey and I'm not sure how long I want to keep the car with other problems like the MFD piling up (radio is out). Plus driving a 2005 I'm really wishing I had some features like TPMS, a backup camera, AEB, etc. I guess I'll likely see most of the $1950 back if I sold the car in a year or two? With gas prices and such, it looks like resale is pretty good. Seeing $6-8k for driveable <200k Priuses (assuming original aged HV battery).
