2005 swapped 3rd gen modules into 2nd gen and now misfire...
Discussion in 'Gen 2 Prius Main Forum' started by 2GenPrius, Nov 8, 2020.
  1. 2GenPrius
    2GenPrius Member
    192
    35
    22
    Californication
    I have a 2005 Prius with about 260K miles on the car. I had planned to get a Highlander Hybrid soon, yet decided to swap in the 3rd Gen battery pack I got on the cheap. It was balanced with a Prolong Hybrid Charger and cycled through with the intelligent discharger. I checked each module after the balancing, they were all within .01 of each other and at least 7.93V.
    I swapped all the modules (boy is that job fun on the 2nd Gen battery chassis, that thing sucks compared to the 3rd Gen!) over, put everything in, made sure that everything was unplugged yet decided to clear the ECU using a bluetooth OBDII device (recommended by Dr. Prius app). Went on a short drive around town, everything seemed to be working great. Stop and go, battery power levels were sustained and working superb. I did this drive for just about over a half hour.
    When I got back home, I stopped the car and turned it off. I then turned it back on and then the engine started shaking really bad. In hybrid mode, no shaking. Figured its a misfire.
    Ran Torque Pro, first got a P0302, Cylinder 2 Misfire. I'm like ok, let's do the coil pack dance. I cleared the faults and I swapped 2 to 1 and vice versa.
    Then I got the first image:
    I'm like wth, ok maybe that coil pack is bad since its starting off with #1. Swapped 1 now to 3 and vice versa.
    I get a pending P0301 flash, not even a sustained error code until I drove it around for about 10 minutes. Hesitation is always there when trying to hit the gas. P0301 now shows as a sustained code but only after driving around. Didn't look at plugs yet, it was too dark out and I wanted time to dig out all 4.
    I just thought it was weird in proximity to the hybrid battery swap, but alas, I drove it around for about half an hour without hitch.
    I felt like driving her into a wall, I was so tired after having the lovely 30-40 mph winds we were having today.
  2. PriusCamper
    PriusCamper Senior Member
    13,447
    5,429
    Pacific Northwest, USA
    Congrats on your successful effort and glad you enjoyed it. Sometime that's the most important part of DIY... As for the new problem. See if Dr. Prius app reads those error codes differently than less good Torque app?
    My impression is that the problem is your engine is jealous you gave so much attention to the hybrid system and now its acting up to get some luv.
    So before you do the coil swap, do new filter, MAF sensor & Throttle body cleaning, new plugs. Also if you're a quart low on oil you can get engine misfire codes that way too...
    I bet once you do all that and reset the 12v so computer's engine settings get a fresh start you won't have to bother with igniters. People always think their igniters are a problem and they rarely are.
    2GenPrius likes this.
  3. 2GenPrius
    2GenPrius Member
    192
    35
    22
    Californication
    Thanks for the reply.
    Been reading around, and it did rain a bit last night. I was wondering if coincidentally while I was driving around I managed to slosh some rain into the ignition system.
    I did check the oil level, and its fine (right on the line actually).
    I read about this online, and mine is a 2005, so gonna check this out tomorrow.
    https://lusciousgarage.com/blog/2004_2005_prius_misfire_condition/
  4. Bunce
    Bunce Active Member
    322
    185
    Oregon
    Sounds like some trouble I had with a bad injector. On startup, rough, like marbles in engine rough, then it settles. Upon gentle driving, just fine. But when flooring it, a misfire code would trip.
  5. 2GenPrius
    2GenPrius Member
    192
    35
    22
    Californication
    That sounds like it too. I did throw in some Seafoam into the gas tank.
    Did you get the flashing cylinder misfire code?
  6. PriusCamper
    13,447
    5,429
    Wow, did not know about that... Thanks for sharing! Will keep an eye out for that!
  7. Bunce
    Bunce Active Member
    322
    185
    Oregon
    I think I did. It was a couple years ago. I tried injector cleaners etc. but it didn't work. you can swap the injectors around and see if the code moves to a different cylinder. I did this and then just ordered a new injector. It's been fine ever since.
  8. 2GenPrius
    2GenPrius Member
    192
    35
    22
    Californication
    Well folks, I was lucky enough to have my cousin swing by who drives a 2005 Scion xB. As some of you may know, a lot of the engine parts are the same on those 1NZ-FE engines. We were able to identify the temperamental/bad coil pack by cycling all four from my engine on his #1 cylinder.
    The code it through was weird, it said something about the circuit not being completed. Vice versa, took his #1 coil with the tested good three, and Prius runs like a champ again. If digging for donors, look for junked xB, xA, Echo, Yaris, in addition to Prius 2nd Gens. The coil packs are the same for those cars.
    Oh, and just FYI, took out the spark plugs and the ceramic sleeve surrounding the electrode chipped off a bit on Cylinder #1. For Cylinders 2-4, its showing signs of burning through, so thinking this is where Cylinder #1 went (I hope). I knew this spark plug ran hot, but didn't know it ran THAT hot. It was on the recommended plugs list for the Prius too. Read on the forum and elsewhere and this seems to be a pretty common occurrence, not sure why spending bank on iridium if they don't last for jacksquat.
    Swapped in some NGK coppers. They wont last as long, but I really didn't like what was happening with the Densos. Terrified me that the ceramic pieces scored up my engine cylinder. I'd like the POS to last just a little bit longer...
    IMG_20201109_123010.jpg IMG_20201109_161035.jpg IMG_20201109_161058.jpg IMG_20201109_161014.jpg IMG_20201109_161136.jpg IMG_20201109_161153.jpg IMG_20201109_161216.jpg
  9. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    whatever sparkplug you have there, it isn't the oem recommended. I've never seen one like that in any Gen 2 I've worked on. It should be an SK16R11.
    What you have there definitely isn't iridium fine wire. Considering one of them looks like the center electrode is worn below the level of the ceramic, looks like someone put 50k miles on a 10k mile chinese impersonator. No real Iridium plug would ever wear like that. If that started as a fine wire and wore down to that? Has chinese counterfeit written all over it.
    I don't think I've ever seen a Gen 2 that got less than 80k miles on a set of real SK16R11 densos..and 90% of those you could clean and put right back in if desired.
    #9 TMR-JWAP, Nov 9, 2020
  10. 2GenPrius
    2GenPrius Member
    192
    35
    22
    Californication
    Thanks. The plugs are supposedly Denso IK16TTs.
    Find My Part
    I read a bit about them on the forum here, said they ran a bit hotter than the standard long-life plug, but improved gas mileage (which was my end goal). Coincidentally, it didn't make a dent on my mpg numbers, yet I figured it was because the hybrid battery was getting tired during summer (which it was, found two modules out of balance and lower voltage than the rest). Turns out the pack was another rebuild from unknown rebuilder (has a mix of modules from two different packs).
    I agree with you that the plugs might be counterfeits. I emailed Denso and the eBay seller I bought them from, kinda ticked off because I just bought the set late July 2020. Since it was during the shutdown due to COVID, I've driven like maybe 1K miles total. For them to fall apart like this means its complete shite. Gonna torch Denso or the eBay seller either way.
  11. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    They are counterfeit. Iridium melts at 4500 degrees. The TT is supposed to be twin tip iridium with a fine wire center electrode. Those plugs look like the center electrode was recycled beer cans.
  12. 2GenPrius
    2GenPrius Member
    192
    35
    22
    Californication
    Agreed, I looked over the Denso guide for counterfeit and these things are 100% bogus. Seller hasn't replied so far.
  13. 2GenPrius
    2GenPrius Member
    192
    35
    22
    Californication
    Threw in a used coil harvested from a junkyard xB and the car is in perfect operating order again. Guess at nearly 275K miles those ignition packs are really, really tired and that a newly juiced hybrid battery pack really gave it a wake-up zap.
    Still at war with the eBay seller, had the audacity to try and offer 1/2 off purchase price. I escalated to PayPal.
