2005 Toyota Prius abs code c1364, c1365
Discussion in 'Gen 2 Prius Technical Discussion' started by Allendubinetsky, Jan 13, 2017.
  1. Allendubinetsky
    Allendubinetsky Junior Member
    Sacramento
    Hi I have a 2005 Toyota Prius with 63,118 miles. A couple days ago during a very rainy week here in Sacramento, I had to drive through a bit of a flooded road nothing much about 1/4 up the tires. I drove the car to the job everything was fine. Parked the car, everything fine. After work about 8 hours later I started the car and the emergency brake was on, even after depressed. Abs light, and brake warning light. After I came home I pulled the abs code c1364 malfunction in w/c pressure sensor and c1365. I cleared the codes and it drove it for a day and then then next day they were back. When I open the door the anti-theft alarm sound with the anti-theft sign on the dashboard. It also beeps when I press the brake pedal. If I clear the codes I can drive the car for a while.
    Please help if you have any idea what's going on. I don't have warranty so I need to locate the problem and fix as low cost as possible. I have some mechanical experience so most of the work I can do myself.
  2. JC91006
    16,939
    8,647
    Maybe you just have a weak 12v battery
    Raytheeagle likes this.
    52,912
    welcome!
    how many miles on her?
  4. Allendubinetsky
    Sacramento
  5. bisco
    52,912
    are you saying you can't release the emergency brake? could be stuck due to the water.
  6. Allendubinetsky
    Sacramento
    If the codes arent cleared the emergency brake "LIGHT" even though it's released
  7. bisco
    52,912
    gotcha. agree with jc above. test the 12v, then read the dtc's if they come back.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Could it also be that water may have gotten into the back and might be around the battery? How long have you owned the Prius? Has this problem been there before the rain?
    Might be worth a look in the back where the battery is at.
  9. Parvaiz Iqbal
    Parvaiz Iqbal Junior Member
    Bradford UK
    Did any one mange to solve this problem,
    Had same issue
    Thanks
