2005 Toyota Prius no starting issue
Discussion in 'Gen 2 Prius Technical Discussion' started by Numbaonenewb, Aug 15, 2017.
  1. Numbaonenewb
    Numbaonenewb New Member
    Portland
    I have a 2005 Toyota Prius. I measured the voltage underneath the hood from the fuse box terminal and its reading 12 volts. I put the key into the slot and push the power button and nothing happens. There is a light with the red car shaped icon with a key blinking.
    Any ideas what this might be? The car doesn't start or run because the power button doesn't do anything.
  2. Numbaonenewb
    Portland
    52,804
    welcome!
    12 volts is too low. a new battery is 13. how old is it? you can try charging, but if it's more than 5 or 6 years, i would replace it.
    52,804
    you need a new battery.
    i've asked the mods to delete one of your threads, two are not necessary.
  5. Numbaonenewb
    Portland
    I've also hooked up jumper cables to the battery in the back and still nothing happened. Headlight shows to be very strong and bright.
  6. Numbaonenewb
    Portland
    I've hooked up jumper cables to the battery in the back and the power button still does nothing. No dash lights come on however the headlights come on strong and bright.
  7. Numbaonenewb
    Portland
    I've also checked fuses as well
  8. JC91006
    16,936
    8,647
    When did this happen? Anything special leading up to this no start?
  9. Numbaonenewb
    Portland
    Ok. Never mind. The dash lights now turn back on as long as the key isn't in that slot to the right of the steering wheel.
    The problem now is the gas engine doesn't start. In the display screen it shows the battery near dead but shouldn't the gas engine still start?
  10. JC91006
    16,936
    8,647
    What did you touch while you were troubleshooting? Did you touch the orange plug on the HV battery?
  11. bisco
    52,804
    two bars is okay, any lower and the hybrid battery won't turn the engine over.
  12. Fred_H
    Fred_H Misoversimplifier
    562
    488
    28
    Germany
    If you can turn on accessory mode and ignition on mode, but not ready mode, then you should check the brake pedal switch.
    Does the "READY" light on the dash light up?
