2005 traction light issues
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Priusflipper, Mar 2, 2016.
  1. Priusflipper
    Priusflipper Junior Member
    Scottsdale, AZ
    Hi guys, i have a 2005 prius, just replaced the HV battery and 12v. But not have 3 codes coming on..
    I added a photo of the lights currently on
    -U0123 "Lost communication with yaw rate sensor module"
    -U0124 "Lost communication with lateral acceleration sensor module"
    -U0126 "Lost communication with steering angle sensor module"
    Not too sure where to start i've located the yaw rate sensor and was going to replace but wanted to see what you guys had to say first. ANY help is very appreciated.
    BTW: It seems to run and drive fine.
    Thanks, Tyler
    #1 Priusflipper, Mar 2, 2016
  2. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Have you tried to clear the codes? All of those sound like possible caused by bad 12V.
  3. Priusflipper
    Scottsdale, AZ
    Tried to clear and nothing happened. Disconnected the 12v and nothing, its reading 12v though.
    52,509
    welcome! maybe 12v isn't enough. a new battery should read 13v at rest. alternatively, some codes need to be reset by a reader.
  5. dolj
    dolj Senior Member
    8,603
    4,365
    Wellington, New Zealand
    Like Bisco says, the ABS (and probably VSC) related DTCs will not be reset by disconnecting the 12 V battery. These can only be cleared by using an appropriate code reader.
  6. bisco
    52,509
    thanks! i wasn't sure about that.
  7. Priusflipper
    Scottsdale, AZ
    I have a Bosch scam tool and have tried a few times and still nothing..
  8. bisco
    52,509
    you might need a prius aware tool, all scam tools are not created equal.:cool:
  9. Priusflipper
    Scottsdale, AZ
    Haha okay thank you! Any idea where i can find one of them? Thanks
  10. bisco
    52,509
    the only one i know of that does it all is the mini vci. there are many threads here on them, it's the official toyota tech stream software. you need an old laptop. it's possible some other scan gauge will work, but i'm not sure.
    Priusflipper likes this.
  11. Priusflipper
    Scottsdale, AZ
    okay great thank you Bisco.
  12. bisco
    52,509
    all the best.(y)
