2005 Trunk Smart Key Entry Not Working
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SwaggyWebb, Dec 29, 2025.
  1. SwaggyWebb
    SwaggyWebb New Member
    Maryland
    Weird issue, my keyless entry was working on my trunk (as in car is locked, I walk up to it and put my hand on the latch and it unlocks/opens).
    Lately that is no longer the case.
    I have techstream and verified that the antenna or oscillator picks up the key for both the interior and exterior rear hatch sensors (as in ran the test and heard a beep when i took the key back there).
    The trunk opens when I unlock the car, so to me it isn't the latch either.
    Any advice on what could be wrong? Is there some part I'm missing between whatever makes the car beep when I run the active test and the actual handle?
    It isn't the key fob either because I tried with both key fobs and got the same results.
  2. Tombukt2
    Tombukt2 Senior Member
    13,717
    2,483
    Durham NC
    But when you walk up to the driver side door locked and reach your hand out it unlocks and you can get in the car and start the car without ever looking at the remote or touching it? You have factory manual steps ?
  3. dolj
    dolj Senior Member
    8,627
    4,381
    Wellington, New Zealand
    You have to do more than reach your hand out; you have to touch the back of the door handle to unlock the door(s).
  4. Tombukt2
    13,717
    2,483
    Durham NC
    .my 09 SKS car right now . I have remote in pocket . I walk up to my 09 extend my hand fingers to the door handle . My hand or fingers have not physically touched the cold azz handle at all . 8 hear the audible click clunk . And then only then do I have to lift the cold azz handle. I'm doing this right now in
    22° weather in front of my house and hdd to Dunkin
  5. dolj
    dolj Senior Member
    8,627
    4,381
    My 07 SKS car right now. I have the remote in my pocket. I walk up to my 07, extend my fingers to touch the rear of the door handle. My hand or fingers have physically touched the handle; only then do I hear the audible click clunk, and then only then do I have to lift the handle. I'm doing this right now in 15°C weather in front of my house.
  6. Tombukt2
    13,717
    2,483
    Durham NC
    Jesus Christ my hand did not touch the door handle until after the clunk and click I have to pull on the handle to open the door not for it to unlock.the sensor don't need touch apparently I guess my finger breaks the circuit ? I don't know . Same at trunk I just stand by the trunk hear the click clunk . Then I have to touch the rubber and lift . I'm standing at the car now . With two buddies of mine they have same car too
  7. SwaggyWebb
    Maryland
    Yeah when I touch the regular driver door handle, the car unlocks.
    When I do the same on the trunk, it no longer unlocks. But the trunk unlocks when i hit the button and I verified the key fob is being read by the car when I'm at the back of the trunk.
    Is there some third part in between the physical trunk lock/button and the receiver for the SKS system? I'm thinking that must be what is bad, but I don't know what part that is or where to find it.
  8. dolj
    dolj Senior Member
    8,627
    4,381
    It doesn't work that way on my 2007 with SKS. For the front doors and the trunk, I have to physically activate the unlock. To me, this seems to be better security.
    I am just pointing out the difference, if it really works the way you are saying.
  9. SwaggyWebb
    Maryland
    So I appreciate you response, and I've read through your P&G link in your signature as well for future use!
    This made me look more into what I actually have in case I was crazy (since I recently switched from a 2007 with 220k miles to a 2005 with 41k miles on it), but both do have a 3 door SKS system. So my drivers door unlocks my door (but I recently switched it to unlock all doors because I usually drive with a passenger besides to/from work), and my passenger door unlocks all doors when I walk up and put my hand on the handle with the fob in my pocket. For some reason my trunk won't do that anymore. But the button on the trunk locks the car when I press it, and the key fob unlocks the car and I can open the trunk. So something between the key signal and the trunk latch is not acting right.
    dolj likes this.
  10. SwaggyWebb
    Maryland
    I am wondering if it could be the liftgate handle assembly or the trunk control module unit (PN 90980-04174)? Something is causing the signal not to get from the car to the trunk release, but the release will work if I hit unlock on the key fob twice...
  11. dolj
    dolj Senior Member
    8,627
    4,381
    I was going to suggest the trunk lock mechanism as I have had that fail, but this does not fit with you description of the symptoms.
    I was then going to suggest maybe it was the lock switch, but that also does not fit with your symptom description.
    The only other thing I could suggest is that the oscillator (as it is called) might not be picking up the signal from your key fob when you are standing at the back of the car. There are four oscillators inside the car; one inside each of the front doors, on in the rear of the center console and the last in the trunk under the floorboard to the rear and left of the electronics bay of the hybrid vehicle (HV) battery.
    I'm not sure how you would test that though. Maybe others could chip in with that.
    [EDIT]
    That is a noise filter condenser, not sure if that is related to your problem. In addition, there is one of those in the tailgate as well (same part number, but PNC 86011P). The oscillator is P/N 89741-47110
    I didn't assimilate this on first read, maybe the lock mechanism hasn't failed completely failed and is sticking or only intermittently working?
    #11 dolj, Jan 7, 2026
  12. SwaggyWebb
    Maryland
    All good points. I have an offline techstream account and was able to run a test that beeps to signal communication from each oscillator when the key fob is near. It works at each location (driver, passenger, back seat, inside trunk, and outside trunk).
    I ran pinouts to make sure no broken wires were hampering my efforts, no issues there.
    I ended up just ordering a new trunk release assembly and will plug that in to see if that resolves the issue. Not sure how, but I'm leaning towards even though the oscillator sees the key fob, when I touch my hand and start to depress the trunk latch, it isn't grounding properly and therefore isn't sending the signal to unlock the trunk. I know the trunk assembly only has 2 wires going from the trunk release and 2 wires going from the sks lock button on the side of the liftgate that then run into the oscillator wiring assembly, so maybe for some weird reason it is that. I'll update this post when I get it in.
    dolj likes this.
  13. SwaggyWebb
    Maryland
    So I swapped the two trunk release assembly, no change. Not sure where to look next at this point, because the car knows where the keys are. I put the keys inside the house and try to hit the trunk lock button, nothing happens (which is correct), then I go get the keys and hit the button on the trunk to lock all doors - all doors lock.
    I checked the actual release mechanism for the trunk, moves super easy, trunk closes and opens no problem.
    So the car is picking up the keys and knows what it is supposed to do, but the trunk won't do it.
