2005 won’t start long story
Discussion in 'Gen 2 Prius Main Forum' started by Vicvelasc, Jan 27, 2023.
  1. Vicvelasc
    Vicvelasc New Member
    Charlotte
    My Prius suddenly flashed the triangle (!) and went into neutral and turned off while I was driving . I rolled into a lot and stopped and then turned it off. I tried to turn on but it just would flash a couple dash lights and a few squares on the dash before going back to off with my power button blinking orange/Amber .
    I looked through this forum tried a few things to self diagnose.
    Checked the battery from the front fuse cover and from the rear 12v in the trunk. Both readings above normal >12 .
    Checked fuses under the hood driver side — no breaks in copper lining. No blown fuses (ab2 or dome etc) . No weird smells nothing .
    Waited awhile , foot off break power button turned green but only the aux screen turned on but nothing else. Pressed power button again and light goes flashing orange/Amber again no lights. I try foot on break and it just flashes orange/ Amber same sequence on dash from prior.
    I recently replaced my inverter water pump located above driver side headlight .Drained and filled back with liquid. Checked in the reservoirs to make sure it was working. Ac and heater worked fine after and was actually using the heater right before this happened. So I was positive it wasn't the pump after reading on here that it may be a reason .
    After all this I decided to get it towed to Toyota for a diagnostic.
    The report states , “ it was found the hybrid inverter water pump has failed and needs replaced , after replacement, will need to proceed further diagnosis”.
    soo my question is - is this a different inverter pump than the one I already changed? The dealer said it’s a different one and it’s priced different than the one I previously bought and installed myself . I can’t seem to find a difference or the one I need so hoping someone can point me in the right direction . Thanks guys
  2. Tombukt2
    Tombukt2 Senior Member
    13,871
    2,521
    Durham NC
    So you bought the inverter pump the one on the gold bracket that goes right under the headlight basically from the Toyota dealer it's a Toyota part?? If so generally that's a real pump and they don't generally fail so I find that pretty interesting that they're saying a Toyota pump failed and they're replacing a different inverter pump there is a pump right up there next to the break actuator and the other brake part on the firewall where your foot touches there is a little pump up there I think it's rated 14.4 volts looks like a mini spa circulation pump and there is another one right in your left front fender at the coolant recovery tank or coolant storage tank this beautiful stainless steel tank that's behind your fender liner and behind your fender on the left side there's another pump that looks like the other one near the brake parts down in that fender so I don't know which one they're replacing I would find that kind of suspect because those two pumps usually last the life of the car upwards of 200,000 near 300 possibly more One guy has 600k on his and I think those pumps are probably original. So it's interesting by looking at this bill or whatever I don't see any part numbers that they're applying or whatever is going on for $800 here I'm on a phone so I have to look at this and try to pinch and squeeze and blow it up and read all the hoo ha.
    52,880
    there have been a spate of black market aftermarket pumps that fail in a short time
    Todd Bonzalez likes this.
  4. Vicvelasc
    Charlotte
    yes the pump I bought was a Toyota part and it’s been on for maybe 10,000 miles . My vehicle has about 220,000. The strange thing is I asked the parts dealer at Toyota if it was the pump I just replaced that was the issue (the pump in front of driver headlight under fuse box) and he said no, that it was a different one. But the description on this ticket says it’s that one — super confusing . Especially because my car wasn’t showing any symptoms of the pump I replaced failing at all
  5. Vicvelasc
    Charlotte
    I read about that . I don’t have an issue buying a Toyota bump , the problem is the pump they said I need replaced is $269 and not the $179 inverter water pump
  6. bisco
    52,880
    the hybrid inverter pump is the only inverter pump. so they are saying the one you changed isn't working.
    you can check the reservoir for movement if you can turn it on as you did before.
    then they are saying more diagnosis will be needed, but i don't understand what they mean. if something else is wrong, they should be getting trouble codes
    #6 bisco, Jan 28, 2023
    Vicvelasc likes this.
  7. Todd Bonzalez
    Todd Bonzalez Active Member
    250
    160
    Ireland
    "After replacement, will need to proceed with further diagnosis"
    A dealer busting out the parts cannon huh? Or maybe they're not interested in working on a 2005 car and this is a PFO...specially if they didn't bother to pull codes..
    You got any good independent shops you can take it to for a second opinion?
  8. highmilesgarage
    highmilesgarage Active Member
    494
    185
    Kansas City
    wow $800 for a cooling service!
    looks like a parts cannon approach, I run away from this stealership. What a waste in $$ for diagnostic. That pump rarely is the reason for a no start condition. They just run their scanner, see the codes and voila! money codes!! no further checking required. Next car..
    Vicvelasc and Todd Bonzalez like this.
  9. ChapmanF
    19,045
    There might be a bit of confusion here. The inverter water pump isn't connected to the heater working. The heater uses coolant from the engine, a separate system.
    The inverter water pump does have an indirect connection to the A/C working, because it cools the inverter, and the inverter powers the A/C compressor, so if the pump fails, the inverter may overheat, and if it does, it may shed the power to the A/C, and then the air blowing won't be cold.
    The pump situation in a Gen 2 is confusing because there are four water pumps in a Gen 2, three electric and one belt-driven. There's only one for the inverter, and the other three are all for the engine cooling system and heat. One of those is kind of near the inverter though. People get mixed up a lot.
    Did the dealer give you any paperwork with the part number of the pump they're proposing to replace?
  10. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    Either someone at the dealer is lazy, or they're not giving you the full story. Yes, if the inverter pump failed then the inverter can overheat, turn on warning lights and shutdown.
    I would expect certain codes to be present if this was the case. I would also expect the car to power on and drive once it cooled off- until it got too hot again.
    Vicvelasc and Tombukt2 like this.
  11. Tombukt2
    13,871
    2,521
    Durham NC
    Yes I can drive my car gently on a 95° day with the sun out and I can go a hundred miles with the inverter pump not functioning at all and when I get to where I'm going or running my route I generally lift the hood and touch my inputs and outputs of my inverter and rarely have I ever seen or felt much above 105 108° . I drove like this for a week running service calls in the summer time never a problem and then I took out of another car the little spa circulation pump looking thing in between the brake actuator and what I'll call the master cylinder which is connected to your pedal I took that pump from another vehicle moved it to my vehicle where the inverter pump goes left the original bracket for the original inverter pump sitting there and everything but in this 14.4 volt rated pump and it's been working now for over a year or close to it and works very well I'll be surprised at this pump ever dies well kind of surprised anyway and the one I've taken off and put on my car has 200,000 mi on it from another vehicle it's just the way the pump is built and designed it's a tried and true type of design not this flat pancake thing that somebody just came up with or whatever happened with that.
  12. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    The symptoms certainly point to an inverter pump failure. Every one I've seen fail has failed electrically. Sometimes they can load the circuit down enough that it doesn't blow the AM2 fuse, but drops the voltage enough to affect the other systems in the circuit.
    Just unplug the pump, replace the AM2 fuse anyway and then drive the car and see what happens. Just keep in mind that if you go highway speeds, you'll likely make the inverter warm enough to code. I think my local Toyota dealership has these pumps for like $140
    I was wrong, it's $124 (item number G902047031)
    INVERTER COOLING. 2007 Toyota Prius Hatchback | Jim Hudson Toyota, Irmo SC
    Vicvelasc and ColoradoCrow like this.
  13. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    May that is a good deal. My local stealership it was $183 out the Door. But when you are down one..You gotta pay for speed. This was on my wifes car and was back when she commuted 100 miles round trip everyday.
  14. Vicvelasc
    Charlotte
    Hey guys sorry I’ve been trying everything with this car. The dealership didn’t give me any more information but did confirm it was the inverter pump they would replace first . So I just bought one myself and replaced it . Issue is car still won’t turn on .. rear battery was drained , got it tested . It is good and recharged . I can’t get any codes read because the car doesn’t go past the first power mode . I press power ,no foot on the break of course, power button is green dash is black besides open trunk light or door etc. Radio turns on and console screen is on lights work etc. But when I press power again to try and go into ready mode it just makes my dash blink squares and the power button blinks orange or amber and then it’s back to off. So now the issue is car won’t start or let me read codes . Inverter was replaced … help
  15. bisco
    52,880
    can you give us the 12v specs?
    what happens when you put your foot on the brake and press power?
  16. Vicvelasc
    Charlotte
    The dash lights up with squares on the right side and then goes dark and power button flashes orange/ amber . It does not start or go into second aux mode
  17. bisco
    52,880
    keep in mind, >12v may not be enough. my 4 year old battery is 12.8v
  18. TMR-JWAP
    6,404
    6,099
    Columbia, SC
    Did you unplug the pump, replace the AM2 fuse with a new 15 amp fuse and then try to start it? Just trying to take the pump and wiring out of the circuit and ensuring the AM2 fuse is good, before sending you elbows deep in more difficult stuff.
    If this fails to change anything, you may have a power source ecu problem. There are other threads on the forum about that.
