2005 wont fill with gas
Discussion in 'Gen 2 Prius Main Forum' started by David Kleinwolterink, Jan 9, 2017.
  1. David Kleinwolterink
    David Kleinwolterink Junior Member
    26
    iowa
    tried filling up this morn and the nozzel kept clicking off , and was air pressure coming back out ,did finally get2/3 tank
    What do you think ?
  2. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Gen2's are finicky to fill in winter, so we have to chalk it up to that unless you continue to see problems. Some say it is the bladder gas tank but I think back pressure (winter fuel butanes) might play a role.
  3. Eastside
    Eastside Member
    129
    82
    NorthVirginia
    It's Winter and time for the seasonal 2005/Gen2 gas pump ritual. My F-150 with the capless fuel filler had similiar issues.
    I don't see much consistency, so it could be the winter gas blend on a given day. I usually fill at the same local station and sometimes the pump clicks off. Come back another day and the pump is fine. . . . Only Shell gas works all the time for me and worth the extra nickel or dime a gallon.
  4. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    I have to stuff mine to get 10 gallons into it. Lots of slow pumping the last two gallons, but it fits.
  5. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    1) the bladder inside your tank is less flexible in cold weather. In MS, I was able to get fill 11 gallons in summer and 8 in winter, temps where you are will vary from MS. (this also effects how far you drive before the first pip goes dark)
    2) try inverting the nozzle so the lever is more vertical rather than horizontal.
    3) open the gas cap before paying, to let air pressure equalize.
    I hope for the best!
    Danny3xd likes this.
  6. Simbaboy
    Simbaboy Active Member
    134
    112
    Mid-Michigan
    I had my first burp and spill yesterday. I should have been more patient and fill the last gallon slowly.
