2005 Won't start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Christina, Apr 4, 2008.
  1. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I would try charging the 12V battery at home. If/when it reads fully charged go through the diagnostic screen and note the voltage.
    You can easily check out your battery status/charging system using the MFD in maintenance mode. No tools required.
    1. Get your Prius into "Accessory Mode" - Press the power button without touching the brake pedal.
    2. Put the MFD into "Maintenance Mode" - Press and hold the "Info" button on the MFD while turning the headlights on and off 4 times.
    3. Press the "Menu" field on the screen.
    4. Press the "Display Check" field.
    5. Press the "Signal Check" field.
    6. The 12v battery voltage will be one of the items listed, it should be above 12 volts. If it is lower, either the battery needs replacement or the charging system is not functioning correctly - see step 7.
    7. Put a small load on the battery by pressing the power button again without touching the brake pedal. The voltage should stay above 12v. If it drops significantly, you need a new battery.
    8. Now get your Prius into "Ready Mode" - step on the brake and press the power button. The battery voltage should immediately rise to 13.8 volts (Your Prius uses constant voltage charging). If it is lower, the battery will never charge; if it is much above 14 volts, your 12v battery will get cooked.
    9. Shutting the car down will reset the system back to normal operation.
    If you need to get a new 12v battery, you can opt for a dealer replacement or get a better battery at a lower price at: http://www.elearnaid.com/12vo1topraub.html
    and install it yourself.
    JeffD
  2. rogart1
    rogart1 Junior Member
    31
    Canada -NS
    Much the same thing happend to my 06 last month . It was the 12volt battery .
