2005 Yellow Warning Light On and Off
Discussion in 'Gen 2 Prius Main Forum' started by ydpplqbd, Oct 20, 2024.
  1. ydpplqbd
    ydpplqbd Active Member
    551
    254
    Hi all, it has been awhile since I ladt posted. Curremtly, I am driving a 2005 Gen2. New problem: yellow dash ligjht next to the CRUISE lamp (yellow lamp is next to and to the right of the CRUISE lamp) and ywo the right of the headlight indicator.
    What does this yellow light mean?
    I cannot find it in the manual. TIA.
    PS Airbag light is on b/c front seats are temporarily replaced with 2007 seats (diffetent harness connectors).
    20241020_063714.jpg d
    #1 ydpplqbd, Oct 20, 2024
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    I believe that light comes on as a 'heads up" freeze warning when outside temp is 37 degrees.
    This link, sheet number 5. Just a warning that outside temp may cause frost on road, etc.
    Toyota Dashboard Warning Lights [FULL] | PDF
    #2 TMR-JWAP, Oct 20, 2024
    ydpplqbd likes this.
  3. ydpplqbd
    551
    254
    Hi there TMR-JWAP, many thanks for your input. Indeed the warning light is a smowflake superimposef over a stick figure that sort of looks like a broken-upside-down funnel.
    PS I did not find the above described snowflake superimposef over a stick figure that sort of looks like a broken-upside-down funnel at the linked URL.
    PPS. I am attaching a better pic of the relevanr symbol. Screenshot_20241020-093623_Gallery.jpg
    #3 ydpplqbd, Oct 20, 2024
  4. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    It is a picture of a snowflake on top of a road, as if you were driving up the road. A solid line on each side and dashes in the center.
    Using the link, go to page 5, it's like the 12th or 13th symbol.
  5. ChapmanF
    19,002
    The road is drawn in perspective, but apparently disappears over a hilltop before the dashed center line and the side lines all meet at the vanishing point.
