2006 220K miles - P0303 & P0125
Discussion in 'Gen 2 Prius Technical Discussion' started by Bryan Holloway, Aug 5, 2016.
  1. Bryan Holloway
    Bryan Holloway Junior Member
    43
    Fullerton, Ca
    I have an INNOVA 31703 code reader and reading my prius as ive been batteling a check engine light. The issue with the engine light is P0420 code that causes the light. But when I go into the "enhanced menu" it shows "Current DTCs, Historical DTCs or Readiness DTCs ". I go toto "Readiness DTC's" and it shows P0303 and P0125. I have seen others in there when I first reset the ecm, but after the light is on I have seen these two in there before. Anyone have any experience with something like this before?
  2. Bryan Holloway
    43
    Fullerton, Ca
    bump, anyone?
  3. JC91006
    16,936
    8,647
    You probably need to replace the catalytic converter first, then address the other errors, if they still remain
  4. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    P0303 is misfire on cylinder 3. Clear that code and swap ignition coils with cylinder 1. If you then get P0301 you need new ignition coil.
    P0125 is insufficient coolant temperature for closed loop fuel control. Very likely just thermostat. Pretty easy job to replace thermostat but it’s hard to bleed the engine cooling system of Prius.
    Bryan Holloway likes this.
  5. Bryan Holloway
    43
    Fullerton, Ca
    The odd thing is, that under MIL lights on the scanner the only code is P0420. If I go to readiness codes, then the P0303 and 0125 are there. But they dont seem to trip an engine light?
