2006 A/C Quit working - What do I need to replace?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by B Fett, Sep 10, 2015.
  1. B Fett
    B Fett New Member
    orlando, fl
    OK so about a week ago the A/C quit working in my 2006 Prius. The center display still works, A/C light comes on, blower works, hot air comes out. I had the system checked (I have access to a shop) and the system is still showing charged, so no leaks.
    I starting doing some research and I found out that the Prius needs a special type of oil to be used when re-charging the A/C. About a year ago I had the A/C recharged and the shop machine used the standard PAG oil for a regular A/C system, not the hybrid stuff. Oops.
    So I need to get this fixed ASAP as I have a newborn and my GF can't be driving around in Florida heat with no AC with a baby in the back.
    What is the damage here knowing the system has non hybrid oil in it?
    What needs to be done and/or what do I need to replace in order to not have a potentially contaminated system that will fail again in the near future?
    A list of what needs to be done with the associated parts and the oil I need would be great. I found multiple threads on the subject but info is scattered and I can't find a solid answer to the question.
    Any and all help is very much appreciated!
  2. Patrick Wong
    18,210
    6,522
    I suggest that you need to find out what diagnostic trouble codes have been logged by the AC amplifier, to see whether a high voltage ground fault has been logged (DTC P3009), which is the typical outcome of using the incorrect compressor lubricating oil.
    You also need to determine the low and high pressure readings when the compressor is running, to see whether the compressor is actually doing its job or not.
    In the worst case, you would need to replace the AC compressor, the evaporator, and the condenser. At the Toyota dealer, the installation of new parts probably will cost more than the value of your 9 year old Prius.
  3. HGS
    HGS Member
    307
    123
    I rebuilt my air conditioner in a truck. I bought the cheapest parts from China I could find and it was still over $1000 just for parts. I did all the labor. So, yes, a dealer would be much too expensive.
    When I grew up only the rich folks had cars with air conditioning. You could make it a couple months til the weather cools and then get though our Florida winters.
    If you are mechanically inclined, you could do some research and learn how to repair it yourself. Amazon has some good vacuum pumps and AC gages/hoses for DYI.
    It's a tough spot to be in with a good used car that may not be worth spending a lot of money on.
    Follow Patrick's advice. Get the available codes and find out what the high/low pressure is with the AC running.
  4. briantodd
    briantodd New Member
    florida
    this happed to me with my 06 after having a mechanic tried to fix my ac when we were on vacation.
    he charged my ac and added dye and oil to system, ac quit working on our way back from vacation
    went do dealer and found out that ac compressor was shot and the real cause of no Freon in system was
    a leaking evaporator
  5. bisco
    52,860
    it's a major undertaking, any way you look at it. prius a/c going down can total the car.
  6. kubasakidragon
    kubasakidragon Junior Member
    california
    My daughters 2004 went down with a bad air conditioning compressor loading down the engine and mimicked a bad battery with slow hill climbing speed. I have located used and refurbished compressors for relatively low cost from $80 to $350 but need a good shop that knows to use ND11 hybrid oil. With 280,000 miles, dealer not an option. I had good fortune finding a shop to replace ICE and transmission for $1400 cash out the door in one day, so there should be a shop for air conditioning to stay within budget around $600 labor.
