2006 Body Control Module replacement
Discussion in 'Gen 2 Prius Technical Discussion' started by tonybluegoat, May 13, 2019.
  1. tonybluegoat
    tonybluegoat Junior Member
    17
    east texas
    I shorted out the headlight function of my 2006 Prius body control module. It was stupid. The markers work, blinkers, etc. So I wired in a manual switch to turn the headlights and high beams. I would like to replace the body control module, but I hear it requires programming by a Toyota service dept.
    Thoughts?
    Thanks,
    Tony
  2. ChapmanF
    19,060
    I've never heard that the body ECU requires any special programming. Maybe check the Repair Manual (more info)?
  3. tonybluegoat
    17
    east texas
    I had someone else I trust say the same. I guess I'll buy one and see one happens. Thanks for replying.
  4. Kwm488
    Kwm488 Junior Member
    38
    Hong Kong
    have you try to replace body ecu? No need to program ?
  5. Knightrider
    Knightrider Member
    150
    36
    Kansas
    So- even with most funtions - I still have no Radio/Dome/Smart key -
    I have MFD function minus the Radio/Clock.
    Think BCM can be the culprit?
    I changed theinteriror fuse block - same functionality.
    #5 Knightrider, Jun 5, 2019
