2006 CEL question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by zytra, May 12, 2016.
  1. zytra
    zytra Junior Member
    78
    california
    I am asking you to "do" what, exactly? Doing the google search? No ty I can do that but if you guys have a good suggestion for experience, what's the harm in asking?
    Anyway, I got a bluetooth reader and a cheapo android tablet on the way. Sadly I've got no old laptop to install those hacked versions of techstream.
  2. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    You asked if the miniVCI you found that is sold by Amazon came with the software - didn't you? How were "we" supposed to know that - you did the search. You apparently did not bother to read the title for the item carefully enough. The title clearly states that the software is included. Is that the kind of help you wanted?
  3. zytra
    zytra Junior Member
    78
    california
    Just wanted to make sure I get the right stuff.
    thank you so much
  4. zytra
    zytra Junior Member
    78
    california
    The one code the car threw at me on Sunday has not come back yet. I'm roughly 1000 miles after I replaced the bad module and on these 1000 miles I'm sitting just than 42 MPG which is quite a bit better than prior to the module replacement and prior to even get codes for that failing block.
    Today I setup torque pro with custom PIDs and so far everything is looking good after 100 miles. Max SOC ~ 70%, all block voltages are within 0.1V.
    I'm logging everything (block voltages, SOC and some other stuff).
    #144 zytra, May 28, 2016
  5. zytra
    zytra Junior Member
    78
    california
    edit: gonna start a new thread.
    #145 zytra, Jun 21, 2016
  6. zytra
    zytra Junior Member
    78
    california
    well =]
    back at it again, got a P0A80 a couple weeks back, discharged, and balanced it once. then came back on the next day. And a few days later it was a pending fault P0A80 and a current fault P3022 (block #12) - and another pending fault (P3024 - block #14).
    So I'm gonna have a go at it again (almost exactly a year later - though last year it was block #3).
    I just wanted to check with the folks in the LA area if they had a specific shop they'd recommend to buy modules?
    Cheers,
    Steve
  7. JC91006
    16,928
    8,637
    Where are you located? You should charge and balance the pack after you replace modules
  8. zytra
    zytra Junior Member
    78
    california
    I will definitely redo that after replace the 2 modules.
    I commute from Santa Clarita to Pico Rivera.
  9. JC91006
    16,928
    8,637
    Prius express sells them. Last I heard, they were $40 plus a core charge of $15 if you don't bring back the bad ones.
    9013 Sunland Blvd, Sun Valley, CA 91352
    Phone: (818) 433-4334
  10. zytra
    zytra Junior Member
    78
    california
    that's where I bought my 2 modules last year. I ended up replacing only one (I had 2 codes but I could only find one real bad module, all others were pretty much the same). I never returned the bad module and I still have the extra one I had bought - not sure if it's still good though, I'll check it before I buy another one.
  11. JC91006
    16,928
    8,637
    LOL. Well last I heard was probably from you post last year
  12. zytra
    zytra Junior Member
    78
    california
    haha well hopefully they're still in business :D
  13. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    Zytra,
    If they are not around anymore, let me know.
    I'm happy to send them out a set of 2 modules to you for $90 including shipping.
    They are boxed up and ready to go.
    You can contact me through PM or my info below.
    Raytheeagle likes this.
