2006 check engine lights including red triangle
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Depinat1, Jun 12, 2023.
  1. Depinat1
    Depinat1 Junior Member
    Virginia
    So I have a 2006 I’ve been having a few problems for several weeks now after replacing the camshaft, I have to get a new diagnosed due to all the lights coming on Estates that I have poor engine power, throttlebody, Cadillac converter needs work on and also I have the big triangle that came on the mechanic told me the big triangle deals with the main computer of the car. The check engine, light and triangle would come on then all of a sudden the other lights would appear for a short period of time. Then the red triangle would go away, only leaving the check engine light on. Now, as I was driving, all the lights came on, including the brake, etc. and there was a loud beeping noise Has anybody experience this or can help.
    52,830
    the only way to determine the problem(s) is to read the trouble codes with tech stream diagnostic software (dealer, good mech who has it, or you can buy it but complicated to set up)
    once you have the codes you can google them for solutions and post them here for more advice.
