2006 cvt-e gen 2 Prius. Tires, need input. best for overall. upsize?
Discussion in 'Gen 2 Prius Main Forum' started by DONNA MILLER, Dec 28, 2017.
  1. DONNA MILLER
    DONNA MILLER New Member
    Brick, New Jersey USA
    Hello Pruis Owners,
    I have a 2006 CVT-E model pruis with over 200,000 glorious miles. It has seen some great sites. Need new tires once again, blew the radial belts out this time. The drag or friction that Hybrids cause to tires is the cause, I am told of so many replacement tires over its life.
    Patience please, I know some but need to ask others for information. So no rude woman comments.
    My question is, can I put on 195/65/15 tires to have it handle better. Do I have to change the wheel to fit the new tire size.
    Thank you.
    Donna
  2. MickyMatter
    MickyMatter Active Member
    260
    168
    Germany
    Mine (European gen 2) has 195/55R16 tyres.
    That means
    the tyre is 195 mm wide,
    the tyre is 55% of the width high (radial),
    the tyre is for 16 inch rims.
    If your original wheels are the same, actually you have 16" rims and you need 16" tyres.
    Changing the 55% will result in another outer diameter which means another top speed and incorrect miles and mph values.
    This could be prohibited. (In Germany it is.)
    Maybe you are allowed to change the width. Thinner would be cheaper, but wider ones have more traction/less slip. Maybe no real profit.
    Not choosing a too high speed index and load index may reduce the costs a bit.
    52,901
    welcome!
    where is brick, and what is a cvt-e model? non north american vehicles are usually a bit different.
    edthefox5 likes this.
  4. MickyMatter
    260
    168
    Germany
    I think the Prius "gear box" is meant. AKA Power split device aka e-CVT. (electric continuous variable transmission)
  5. bisco
    52,901
    oh, thanks. i thought they were all the same. maybe in brick, they have other types of 'gear box' models.
  6. MickyMatter
    260
    168
    Germany
    I think they are all the same, too.
    But even then, she is right: Her Prius has the so called eCVT.
    ¯\_(ツ)_/¯
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    195-65-15 is the stock wheel size. Do you have aftermarket wheels?
    Go to tirerack.com and search the size and look at reviews. There are a few questions you need to answer.
    Are you after mileage
    Are you after quiet and comfort damn the mileage
    Will the car see snow so must be all season.
    Tirerack will drop ship to just about any tire store on the planet. if you have a tire store you like check with tirerack if you find a tire you like and see if its on there preferred dealer list.
    And hybrids does not cause drag or friction to a tire. You must have been told that horse hockey by a tire salesman.
  8. JC91006
    16,939
    8,647
    Gen2 came with 185/65/15. Gen3 had 195/65/15. Either would fit. I have both on my gen2 cars
  9. edthefox5
    10,096
    4,840
    Clearwater, Florida
    My car came with 195.
  10. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Oh wait I may have changed it to a wider tire 7 years ago lol...
  11. dolj
    dolj Senior Member
    8,655
    4,406
    Wellington, New Zealand
    185/65/R15 is correct and was the Gen 2 stock size in the US, but if you're going to 195 then 195/60/R15 is what you're after. That was stock in UK/NZ/Aus for the 15" wheels and may be other places too.
  12. DONNA MILLER
    Brick is in Ocean County New Jersey. USA. The Beach or ocean/ East Coast of NJ. Generation 2, That is what my recent dealer info sheets listed my vehicle as.
  13. bisco
    52,901
    thank you, all the best with your tire decision!
