2006 Engine Noise
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Adam Evans, Jan 25, 2016.
  1. Adam Evans
    Adam Evans Junior Member
    Our 2006 just hit 150k miles and has been running fine, aside from a slide leak somewhere in the fuel system. Had the fuel filler neck replaced and that fixed it for a bit, then the check engine came back on and we haven't done anything about it since (We cannot smell anything). See this thread for more info on that (Fuel Tank and Canister Replacement | PriusChat)
    In the last few weeks, a rather unsettling noise has started and seems to be coming from the engine, right behind the center console. The noise sounds similar to driving over rumble strips, but higher frequency and the vibrations are much less intense, but can be felt through the gas pedal. I can't find any consistency with when it happens - it'll happen when coasting, increasing speed, braking, and it seems to just come and go. It does seem be happening more frequently. I am not expert, but it does not seem like it is coming from the wheels or back of the car, and the noise does not change based on speed.
    Just looking for any suggestions before I take it to get it looked at. Because the check engine like is on from the evap issue, we aren't sure if it 'would' be on for whatever this new issue is. I've posted a video to youtube trying to show the noise. In the video, it is the noise that sounds like car passing me, but doesn't go away. Ignore the mess, I was on the road for a few days for work..
    #1 Adam Evans, Jan 25, 2016
    52,776
    maybe an engine mount, or manifold leak?
    #2 bisco, Jan 25, 2016
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Is the car a rebuilt title or bought at auction? And your video says disabled. And how do you know fuel is leaking if you can't smell it?
  4. Adam Evans
    Sorry, the video should work now. Now rebuilt or from auction. We are the 2nd owner, bought it with 62k miles in October 2012. All serviced at the local dealer before we got it.
    With the evap, I am going off of the codes, and what a few different garages told me. I had a separate post on here regarding that (Fuel Tank and Canister Replacement | PriusChat). Dealer wanted to replace the tank, canisters and lines. The local garage said it was the fuel filler neck. They both did the pressurized smoke test to find the leak.
  5. edthefox5
    10,096
    4,837
    Clearwater, Florida
    nope...no video...
    Most canister failure codes we have seen are destroyed by fuel. This is from constant topping off of the gas tank resulting in gas overflow from the filler neck and captured by the fume recovery system. Does not take much raw gasoline to ruin the vapor canister system.
    Expensive repair.
    Never seen a "leak" mentioned here.
    Top off of a G2 Prius is bad. First click off hang the pump up.
  6. Adam Evans
    Not sure why the video is not working - I tried making adjustments to the settings again..
    I really don't think the noise we are getting now has to do with our previous issues (most likely) - it's just that the Check Engine light is on because of the previous issues, so I wouldn't know if it were on because of the new issue.
    My wife and I never top it off, but it is possible the first owner did, leading to the issues we have with the system now. I am going to take it to the local garage and have them test drive, see if they can identify it.
  7. Adam Evans
    For anyone reading this, it was the front passenger side wheel bearing. I was pretty surprised by that, as I have had wheel bearings go in my old Subaru and it sounded nothing like this. Happy it was nothing more catastrophic as I originally feared.
