1. The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
2006 Gen2: P0012 Code and heavy oil Consumption
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BigSkyBen, Jul 13, 2020.
  1. BigSkyBen
    BigSkyBen New Member
    Coatesville, PA
    I just took my 2006 Gen2 (142k Miles) on a 500 mile one way road trip. Once there I checked the oil and realized I had burned .75 quart of oil. I added new oil and while at my destination the P0012 (Camshaft Position 'A' Timing Over-Retarded Bank 1) code popped. I cleared the code and not long after, during local driving, the code came back. I am assuming the oil burning and the P0012 code are related.
    Any recommendations?
  2. SFO
    SFO Senior Member
    5,263
    4,216
    Northern California
    Welcome to PriusChat!!
    Here is the workup for DTC P0012 (and P0010 P0011 P0016) : https://attachments.priuschat.com/attachment-files/2018/04/144690_VVT.pdf
    Best to go step by step though the above workup, but given the mileage you might try step 4 and see if the 'oil control valve filter" is clogged.
    Which device are you currently using to retrieve the OBD2 codes with?
    What brand/weight of oil have you been using, and what is the change interval?
    Check for dealer maintenance by running the VIN at : Welcome to Toyota Owners
  3. BigSkyBen
    Coatesville, PA
    Have had an oil burning issue for awhile and ran it low once (didn't know about the oil burning problem before that).
    I use Pennzoil High Mileage 5w-30. Keep to the 5,000 mile oil change schedule.
    I have a Harbor Freight OBD2 code reader and a Bluetooth OBD2 Sensor and Torque.
    Purchased in March 2019 from a friend who was OG owner. All dealer maintained until I purchased. They had put around 115K on the car.
    SFO likes this.
  4. BigSkyBen
    Coatesville, PA
    Should I be doing anything different?
  5. ydpplqbd
    ydpplqbd Active Member
    542
    248
    Once you start using "high mileage" oil, you are supposed continue using it. My 2006 Gen2 oil was burning 1/2 quart of oil every 1500 to 1800 miles when I first purchased it.
    My Gen2 no longer has any material oil consumption after doing the following: i.) changing oil intervals to 3500 to 4000 miles; ii.) installing oil catch can; iii.) "short-sticking" oil level at each oil change by using only 3.5 quarts (rather than the 3.9 quarts for max capacity) which reduces windage; and iv.) using straight 40W Shell Rotella* for the past 12,000 miles.
    *- Shell Rotella has a lot of detergent, anti-sludging and anti-gumming additives which I attribute to un-gumming my oil rings.
    Also see this thread: 2006 Gen2: Oil Consumption Almost Completely Reduced | PriusChat
    #5 ydpplqbd, Jul 16, 2020
  6. Bobbytwotaps
    Bobbytwotaps Junior Member
    HAWAII
    I bet your PVC valve has never been changed on that car. It's not the easiest change on these Prius but not impoßsibe if you are determined. A clocked PVC valve can make you burn A LOT of oil. YouTube it, 10$ part.. worth a try.
  7. SFO
    SFO Senior Member
    5,263
    4,216
    Northern California
    Keeping it under 75mph on the flats and or the RPMs on lower side when climbing or taking off, may help mitigate oil consumption. Using a higher weight oil when temperature appropriate may help as well.
    You might try addressing some of the oil consumption by using an engine flush with something like : Kreen (mail order), Berrymans B12 chemtool (most chain stores), BG products EPR (local repair/parts shops may sell to you over the counter). I've used the last two products before with minor success, and would be most interested in trying the Kreen product going forward. There are other options on the market, most sell for under $10 per use, and the B12 is like $20 per gallon, which would be for multiple uses (have used it as a flush, and in the gas tank, have yet to use it as a piston soak). Let us know which product(s) you try and if you notice any reduction in oil consumption.
    Not sure if that Harbor Freight OBD2 reader is fully hybrid compatible or not, many like to use a 'mini-vci' cable and techstream (dealer tech software). Though not as good as a techstream, others get by with using the OBD2 bluetooth adapter with an app like Dr Prius (or Torque). Make sure the OBD2 adapter you have was quality built (and fast enough to work with Dr Prius) by visiting and reading this webpage : Hybrid battery diagnostic and repair tool for Toyota and Lexus
    Have you had a chance to go step by step through the workup, or check/clean the VVT filter?
    Did you retrieve that P0012 with both the HF reader and the Torque app?
Loading...
