2006 HID Auto Leveling Sensor Picture
Discussion in 'Gen 2 Prius Main Forum' started by larry9901, Apr 17, 2010.
  1. larry9901
    larry9901 Junior Member
    44
    michigan
    Well,
    I got the sensor out and opened it up.
    This is it. I think it is wasted.
    Anyone think it is salvagable?
    If not, any suggestions as to where I can get a replacement for the cheapest price?
    Is this covered by the tsb for no cost? Car is a 2006 with 40k miles
    If so, can someone post the tsb?
    Or, is there a way to turn off the icons illuminated on the dash. I would really like to just turn off the symbols and manually aim the lights.
  2. Patrick Wong
    18,200
    6,492
    I agree that the part needs to be replaced. The applicable warranty would be for 3 years / 36K miles. If you don't want to replace the part I suppose you could put black tape over the dashboard warning lights, but that seems to be a half-a__ repair.
    The part # is 89408-47010 and is pretty expensive at $347 MSRP, $264 plus shipping here:
    http://www.trademotion.com/partlocator/index.cfm?action=searchCatalogOEM&siteid=213747
    51,082
    mine went within a year on my 04. they covered it. of all the things i would never ask for on a car, that has to be near the top.
  4. northwichita
    481
    102
    29
    Wichita KS
    Thread with some more info here , including the fact that parts can be bought from a lexus that fits, if that happens to be cheaper.
    http://priuschat.com/forums/knowled...04-broken-auto-leveling-headlights-fixed.html
    How to aim headlights on a prius, just saw this article today. This also contains advice on lubing the sensor to keep out moisture, I should probably do this soon.
    How to Aim Headlights on a 2005 Toyota Prius | eHow.com
    As to your last question, I suppose a resistor could be place in the connector to replace the sensor, but are you sure your car's height will always stay the same, they really are bright. I really do like my HID headlights, no problems so far, I'd recommend just buying salvage, and adding some silicone grease as recommended above. I drive in the country a lot, last year I zip tied on one end a loose piece of inner tube rubber as an additional cover on the sensor to help keep out moisture and dirt. I fastened this on the body of the sensor, draped over the little arm, I believe your picture has it upside down as to the cars connection.
    http://priuschat.com/forums/attachme...sor_repair.pdf
    good pictures of a repair in this one
