2006 HV ECU Question
Discussion in 'Gen 2 Prius Technical Discussion' started by Knightrider, Mar 7, 2019.
  1. landspeed
    landspeed Active Member
    387
    210
    NZ
    2003 Prius
    I agree fully; the ECU is almost unbreakable (except when it does the plasma-arc thing); even then it usually works and could probably be repaired given how much they cost new. Toyota says 'replace the battery ECU' - they certainly make a profit looking at it like that, and they can then say 'you have a new ECU, but you need a new battery'.
  2. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    I don’t think I have heard of water getting into the battery. Number one reason seems to be electrolytes leaking.
  3. Knightrider
    Knightrider Member
    150
    36
    Kansas
    They are keeping their 06
    The 05 is what I am purchasing- it has been diag w a bad HV Battery
    The 06 is what I will be looking into w the above flow chart.
  4. Knightrider
    Knightrider Member
    150
    36
    Kansas
    I suppose it would need to be 2" or more deep to pool up in the basin- and fill the spare tire well before that.....
  5. Skibob
    2,912
    1,505
    Northern California
    I don’t know if the dealer can actually see the board without actually removing the battery or not. When you have the battery out take a picture of the board and post it here. There are a few guys that can tell if the board got fried from a picture, or at least can verify is they see the burn spots.
    I like this video for the procedure of removing the battery. It gets the top cover off but doesn’t go into the ECM part.
