2006 ignition falure after replacing both batteries
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by imano, May 15, 2016.
  1. imano
    imano New Member
    arkansas
    I replaced hv battery and starter tried one time to engage and then nothing. i replaced 12v and still nothing. switch powers on and when pushed again simply powers down.
  2. Patrick Wong
    18,199
    6,464
    When was the last time the car operated correctly without any warning lights on?
    What does "starter" mean in your first sentence?
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,365
    3,209
    Madison, Wisconsin
    Are there error lights on the dash?
    Did you correctly reseat the orange safety plug in the HV battery? It is a 3 step process ending with sliding the handles downwards.
    48,976
    welcome to priuschat! how many miles on her?
  5. imano
    imano New Member
    arkansas
    i replaced the high voltage battery about 1 year ago. without any issue. Approximately 1 month ago the "red triangle" and associated lights and codes returned. i contacted the the parts people that had supplied the replacement battery and they had another Dorman battery shipped in. i replaced the battery expecting that order had been returned to my universe, however when i tried to start the prius the engine attempted to start and then there was an audible pop from behind me and then nothing. i replaced the 12v battery for good measure and re-installed the still operational " coding" battery without success. The start button is pushed and all the lights come on and when i depress the brake pedal and push the the start button a second it just turns off.
  6. JC91006
    16,470
    8,383
    Did you install the orange safety plug on the hv battery correctly?
    What code did you get to determine battery was at fault?
  7. imano
    imano New Member
    arkansas
    approximately 170000 miles. it was operating when i replaced the battery.
  8. imano
    imano New Member
    arkansas
    the replace hybrid battery code. there were others that stayed gone after being reset but the replace Hybrid battery code always returned. the plug is correctly installed.
  9. JC91006
    16,470
    8,383
    Then you have a bad replacement battery
  10. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    What JC says above.
