2006 LCD screen flashes "PROBLEM" no explanation
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by leowesman, Jan 30, 2011.
  1. leowesman
    leowesman New Member
    San Diego
    2006 ~80K miles. Occasional beep sounds, once accompanied by lcd screen displaying word "PROBLEM." I stopped switching off vehicle. Next time when turned on it behaved normally, but I am spooked that something major will happen.
    Owners' manual doesn't show anything.
    What is the most likely interpretation?
    Thanks
    Leo
  2. derkraut
    derkraut Member
    299
    27
    SAN
    I have a 2006 with 40K mi; but I've never seen this message. Hmmmm? Maybe it was just an "anomaly". I wouldn't worry about it unless it's accompanied by some other indication.
  3. vertex
    vertex Active Member
    670
    143
    new york
    2018 Prius Prime
    Do you have the original 12 volt battery? If so, change it!
  4. pEEf
    pEEf Engineer - EV nut
    720
    576
    Berkeley, CA
    Vertex is on the right track, a low 12v system can cause this. It's worth at least having the battery checked, though I wouldn't recommend just blindly replacing it.
    Rarely, I have seen an error on the CAN bus cause this, and it self-recovers, so it's nothing to worry about.
    If it is serious, the car will set a code and you will get a triangle of death.
  5. Patrick Wong
    18,199
    6,464
    When was the last time that you checked your engine oil level? If you haven't checked it for a while, I suggest you do that NOW.
  6. leowesman
    San Diego
    Here's the resolution: We had the oil changed at Walmart and they had not reset the computer. We do still have the original 12 V. battery that so far has not shown a need to replace, but will keep an eye on it. Thanks for the responses! Leo
  7. richard schumacher
    7,663
    1,038
    United States
    The "Maintenance required" indicator is supposed to be reset after an oil change. "Problem" is not the same indicator. You may still have a problem.
  8. leowesman
    San Diego
    Toyota service personnel performed a $155 check on all systems including battery and found nothing else at fault. However, only time will tell whether another fault was not diagnosed. Thanks! Leo
  9. richard schumacher
    7,663
    1,038
    United States
  10. ThatCrazyLady
    ThatCrazyLady Junior Member
    Atlanta
    I became thankful for the above conversation this week. Oh boy, how the internet changes things. Here is my experience with this.
    Took my Prius in for an oil change on Monday. Here I am SAHM in during business hours with lots of time to spare sitting there in my yoga pants waiting. The service advisor approaches me over an hour later showing me my engine air filter covered with Live Oak nuts and leaves telling me it needs to be replaced. I know how old it is and I know it does but to go through cleaning the filter at the windshield was too much. (yes it was clean when I got the car back) So they sell a cabin air filter and engine filter, that I’m capable of changing myself, with the oil change.
    Then on Friday the error in this thread appears. I see on this and the other boards that it is oil related. I look at the oil and under the car. CRAP! They spent more time selling those air filters than properly screwing on that oil filter. Oil all over the bottom of the car and on my clean garage floor very little in the car. (pinch in the O-ring!)
    Yea, lost a customer over the sale of $80 in filters. Never assume the woman knows little!
  11. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    746
    Delaware
    where did you go? I would call them and tell them their "tech" is incompetent and will cost them big $$ in blown up motor lawsuits.
