2006 non-HID lights keep burning out
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Twigs, Dec 28, 2014.
  1. Twigs
    Twigs Junior Member
    Washington
    2021 Prius
    LE AWD-e
    I have a 2006 Prius and for the past four years I have to replace my headlamps at least once a year. These are not the HID headlamps that were notoriously an issue. However, I replaced them this past July and they've both burned out again in the past month. It's becoming a huge pain, even though my mechanic in town manages to do this chore for me for less than $25 per headlamp. Any advice or experiences you can offer to this frustrated owner...my dealership is playing dumb about this problem.
  2. Patrick Wong
    18,210
    6,515
    1. Measure voltage across the 12V battery when the Prius is READY. If it is too high that would be the root cause of the problem.
    2. What brand headlight bulbs do you install?
    3. How many miles do you drive in a year and do you leave the headlights on at all times - or not?
  3. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    I use the lower brightness headlamps which last the longest. Brightness seems crappy though.
    If you look at the lights at Walmart (for example) they show on the package chart of expected life vs. brightness.
    Basically the brighter you choose, the lower the life is.
    By the way, you are getting a great deal...Toyota would charge you $200 labor to change out the lights that cost you just a few bucks at Walmart.
    Its pretty hard to change out the lights although once you get the hang of it it gets easier. There are some YouTube videos.
  4. Twigs
    Twigs Junior Member
    Washington
    2021 Prius
    LE AWD-e
    I have always left my lights on since I drive a small car and I live in a rural area where much of my driving is done on two lane roads. I'm not sure what brand my mechanic uses, I suspect they are the generic version that NAPA sells. I know I'm getting a huge deal on the replacement...my mechanic put in a new water pump and serpentine belt last summer for half of what the dealership quoted me. I will ask him to measure the voltage today when I am in to get this latest bulb replaced.
  5. Patrick Wong
    18,210
    6,515
    OK, suppose you drive 15,000 miles per year at an average speed of 35 mph. That means the lights are on 430 hours per year. Adjust this computation for your actual driving experience.
    According to your post, you had last replaced the bulbs in July 2014, then in December 2014, so the bulbs lasted 5 months. That would imply the bulbs only lasted ~200 hours given my assumptions above.
    This website suggests that halogen bulbs should last 450 to 1,000 hours: How long do halogen headlights last? - HowStuffWorks
    This website suggests that driving over rough, bumpy roads will shorten the life of halogen bulbs. Is that how you would characterize the two lane roads that you drive upon?
    How Long Should a Car's Light Bulbs Last? - KickingTires
    Since you consider that leaving headlights on at all times is a safety measure, perhaps you need to accept the frequent bulb replacement as a tax that you are paying for that safety.
  6. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    I suspect that this is your problem. Some will argue that this is not the case, but I feel that the Prius, like any other vehicle, has voltage instability (surges/spikes) when first powered on. These can shorten the life of your bulbs. If you turn the lights off before starting your car, and wait even a few seconds (5 is good) before turning your lights on, the current in the light circuit will have settled.
    I had a relay fail because the coil contacts became fouled from arcing at 6 months. I suspected the contacts were chattering from unstable current during startup. I replaced the relay and also installed a delay timer relay in series before the main relay. The delay has protected the relay contacts and it has been problem free for over a year.
  7. xliderider
    8,140
    3,277
    Honolulu, HI
    Try turning your lights off, either before shutting down, or before starting up. Then turn your lights on, after at least a 5 second delay after starting your car.
    Then get back to us in 6 months to report that your bulbs are doing well. ;)
    This is assuming that your mechanic isn't fouling the bulb with greasy/oily hands. Touching the glass envelope of the bulb will cause shortened bulb life due to hot spots that will cause failure of the glass capsule.
  8. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    ...my wife insists on keeping lights on at all times.
    We are still getting long bulb life anyway but we use the dimmest standard brightness bulbs.
  9. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    I keep my lights on all the time. The first set of bulbs lasted 7 years.
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    Aftermarket bulbs last about a year. If u want long life Go to the dealer and buy the original bulbs.
    My original bulbs lasted about 5 years with lights always on. The aftermarket Phillips bulbs although very bright last 9 months.
    This reminds me I have 2 bulbs out so tomorrow I am going to the dealer and buy
    The OEM bulbs and give them a try.
    And your right i find it very hard to replace the bulbs. I did it without taking the front
    Bumper down twice now and it sucks. Bumper this time.
    #10 edthefox5, Dec 29, 2014
  11. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    if the drunken morons and texting idiots out there can't see your car in broad daylight, the headlights really aren't gonna help much. use the money you save on bulbs to buy decent horns to replace the joke "meep" oem horns.
