2006 P3190 P0a0F,not maf.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Njapilot, May 12, 2020.
  1. Njapilot
    Njapilot Junior Member
    29
    DFW
    So 2nd time car went into limp mode, then refused to restart the ice. Cleaned the MAF sensor, car burns oils, so I check it daily. never let the car go below 3 bars of gas. 290xxx miles.
    This last time it did it to me, I put on a jump starter battery pack on the 12v battery and the car fired right back up.
    What is weird is I put a volt meter on the battery and it reads 12.6, I go into service check page (flipping the light switch on and off) it reads 11.6.
    any help would be great.
  2. Njapilot
    29
    DFW
    yellow top battery that is about a year old, and newpriusbattery pack that is about the same.
    52,848
    the battery is failing under load. try a free load test at an auto parts store
  4. Figster10
    Figster10 Member
    207
    61
    Sacramento
    Did you fix the issue?
  5. Sally Starling
    Sally Starling New Member
    Georgia
    Mine is doing same and both batteries are new
