2006 Prius 175K - need to fix HV battery in Michigan
Discussion in 'Gen 2 Prius Main Forum' started by rgrajanin, Jun 27, 2021.
  1. rgrajanin
    rgrajanin Junior Member
    23
    Michigan
    2006 Prius 175K - need to fix HV battery in Michigan -
    I was using the car 4 months before and I stopped using it. Car will not come up. Jump started. Shows red triangle, P0A80 code. Dealer quoting $2900 + labor for HV battery. Any leads please? Thanks in advance.
    51,937
    you want to fix it? (unreliable) orreplace it? (reliable)
    eric becky is in madison wi, and autobeyours is in scottsburg, in.
    might be others closer, whereall in mi?
    rgrajanin likes this.
  3. rgrajanin
    23
    Michigan
    I am not going to fix myself. I am in Rochester Michigan.
    51,937
    i meant your title: 'need to fix' fix or replace? i assume the dealer quote was replace
  5. bisco
    51,937
    call them and ask if they know anyone closer to you. call minnesota hybrid battery too. ask for brad
    and it is steve at auto be yours
  6. rgrajanin
    23
    Michigan
    I need to talk to some of these suggested shops. Meanwhile when I try to jump start, it is not coming up. Does it mean 12v is also gone or it is still hybrid only?
  7. bisco
    51,937
    12v is dead from sitting. how old is it? 4 or 5 years, replace. newer, you can try charging it, but keep an eye on the voltage, could crap out again
  8. rgrajanin
    23
    Michigan
    Sure will try. I think it's around 5 years. Thank you.
    #8 rgrajanin, Jun 30, 2021
  9. rgrajanin
    23
    Michigan
  10. bisco
    51,937
    refurbished batteries are like whack a mole. you replace one module, and another bad one pops up.
    as long as they stay in business, don't give you a hard time every time your car throws a triangle, and you don't mind the down time, it sounds good
  11. rgrajanin
    23
    Michigan
    Finally fixed with a dealer. Looks like some dealers /toyota owners website shows the price of HV battery - few sell for 1650$ but for shipping to home and if someone wants to do DIY. ( same dealer said over phone - if he has to replace it is 1950$ + labor).
  12. dolj
    dolj Senior Member
    8,446
    4,291
    Wellington, New Zealand
    $1650 is the wholesale price; $1950 is the recommended retail price, so it sounds about right.
