2006 Prius, 219K, Connecticut, $3000
Discussion in 'Prius Cars For Sale' started by bgr, Jul 28, 2022.
  1. bgr
    bgr Junior Member
    I am selling my 2006 Prius that I purchased new in March 2006 and now has about 219K miles on it. It’s a package 6, so it has HID headlights, JBL, backup camera, smart key, stability control, auto dimming mirror, and Bluetooth for phone. There’s nothing mechanically wrong with it. The tires have 4mm of tread, and also included is a set of Michelin X-Ice snow tires (5.5-6mm of tread) mounted on factory wheels. It’s had synthetic oil since the 10K oil change. The only modifications it has are the Touring rear sway bar and 195/60-15 tires, which significantly improved the handling. This is by far the most reliable car I’ve ever owned. I think the only time the check engine light has ever been on was when the hybrid battery needed replacing. All recalls have been done. Most maintenance/repairs were done by me using either Toyota or higher-quality aftermarket parts. I have the full maintenance record for anyone that is interested, but since it would be a long list, I’m just putting what I think are the key things here:
    95K – Water pump (Toyota) replaced
    96K – Hybrid battery replaced under warranty at dealer
    115K – 12V battery replaced (optima)
    151K – Struts/shocks (Monroe) and strut bearings (Toyota) replaced
    165K – Engine coolant changed (also done at 95K)
    166K – inverter coolant changed (also done at 89K and 123K)
    181K – knock sensor replaced (Beck Arnley)
    184K – Sway bar links (TRW) and bushings (Moog) replaced
    190K – ball joints replaced (Toyota)
    192K – belt replaced (Toyota) (also done at 95k)
    198K – passenger-side front wheel bearing replaced (Toyota)
    205K – driver-side front wheel bearing replaced (Japanese aftermarket – I think it was NSK)
    205K – Headlight level sensor replaced (Aisin)
    209K – control arms replaced (Beck Arnley)
    209K – changed ATF (also done at 98K and 152K)
    213K – new pads and rotors (Bosch) (also done at 136K)
    215K – Brake shoes replaced
    218K – Muffler replaced
    Now for the not so good parts: The bumper cover (not original) and hood have the normal chips and imperfections. The passenger rear rocker panel has the rust that is typical for this car in this part of the country. There’s also a scrape with a bit of panel damage above that on the door/quarter panel. Finally, a tree branch fell on it a few months ago, denting the roof above the rear passenger side. It’s all cosmetic - the door still closes as it should and there have been no water leaks. I’ve tried to show all of this in the photos.
    I’m selling the car because I’m moving and it doesn’t make sense to take it with me. It won’t be available until around August 7-9, but I’d be happy to show it and take a deposit before then. Located in west-central CT. Feel free to PM me with any questions.
    IMG_8930.JPG IMG_8931.JPG IMG_8932.JPG IMG_8933.JPG IMG_8934.JPG IMG_8935.JPG IMG_8927.JPG IMG_8928.JPG
  2. PriusCamper
    PriusCamper Senior Member
    13,467
    5,435
    Pacific Northwest, USA
    I encourage you to reconsider you price... Two years ago it would of only been slightly low... But out here on the west coast an equivalent Prius would sell for three times what you aking. I even saw one like this in Portland, OR., but with only 27K miles, that was selling for $17K. Don't leave all that money on the table!
    Bohemian Grove likes this.
  3. ttou68
    ttou68 Active Member
    351
    211
    Just curious, have you seen the body damage and rust on this vehicle?
  4. jteran5
    jteran5 Active Member
    413
    203
    2019 Prius
    XLE AWD-e
    I'm interested but can't PM here. Shoot me an email at jteran12 @ Gmail. Com
  5. bgr
    bgr Junior Member
    Update: SOLD
    Happy to have sold this car to a fellow PCer. Apologies to anyone who PMed me and I was not able to respond to while in the midst of moving.
  6. bisco
    52,863
    congrats!
