2006 Prius, 41K miles rumbles when I put in reverse or drive!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Andrea L Chase, May 1, 2022.
  1. Andrea L Chase
    Andrea L Chase New Member
    Started my 2006 Prius this afternoon and it rumbled when I put it in reverse. No lights on dashboard. I also did that when I put it in drive. It wouldn't move either (probably a good thing!). What is happening? Thanks!
  2. JC91006
    16,936
    8,647
    Did it Rumble like a loud motorcycle? If yes, then someone stole your catalytic converter from under your car
  3. Andrea L Chase
    Yipes! I didn't see any damage on the car. Is there a quick way for me to inspect?
  4. JC91006
    16,936
    8,647
    On the passenger side, under where the passenger door is at, if you see some cut wires dangling, that’s an indication the oxygen sensor has been cut off. That’s usually cut when they steal the catalytic converter.
    if you have full coverage insurance, that should be covered
  5. Andrea L Chase
    Bingo! And I park in a.covered, locked garage! Is it normal for there to be no warning lights?
  6. bisco
    52,863
    how did they get in?
  7. JC91006
    16,936
    8,647
    Yeah, these thieves could be your neighbor.
    if you drive around for a few miles, the check engine light will light up
  8. Andrea L Chase
    Following someone in or sneaking in under the garage door as it's closing. I had a window smashed a few years' back. Sheesh.
    Somehow, though, I'm glad it's not the car itself breaking down. It's a sweetie!
    How long can I go without driving it if I start it up every few days? It may be a few weeks before I can get it repaired. Anyone know a good shop in San Francisco?
  9. bisco
    52,863
    luscious garage.
    disconnect the 12v negative and you won't need to start it unless it will be a few weeks or more, the hybrid battery might go out of balance.
  10. Andrea L Chase
    I hear great things about them!
    Will starting it cause more damage with the catalytic converters gone? I'm so ignorant about these things! Thanks so much for the info!
  11. bisco
    52,863
    i would call luscious and ask them. they've seen a million of these stolen cat cars. and keep in mind if you decide to fix it, it will probably just get stolen again.
    although i read cali is allowing an aftermarket unit which might be less valuable to thieves. luscious should know.
  12. Andrea L Chase
    Any idea why it won't go into reverse? Is there some other damage that might have occurred even though there are no warning lights on. Thanks again, PriusChat crew!
  13. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Not sure why it won't move. We've driven lots of cat-less Gen 2 Prii into our shop so we can get them on the hoist & fix them. Also, it would rumble once the ICE starts whether it's in park, drive, reverse, or even neutral. This is probably a silly question, but in all the confusion of the experience, did you maybe leave the parking brake engaged? No shame in that when all you can think is "What the heck is all that racket??!!"
  14. bisco
    52,863
    does the 'ready' light come on?
  15. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    Be very careful not to drive it if the O2 sensor wires are dangling. Short them out and you just make the car a salvage vehicle. Hopefully you have comprehensive insurance because in California you’ll need it to buy a new CARB cat.
  16. Andrea L Chase
    The ready light is on! And still not warning lights. It begins to rumble when the gas engine engages. It's on electric for the first minute or so, yes? Thanks again!
  17. jerrymildred
    11,517
    14,171
    Tampa, FL
    It's on electric for about the first seven seconds.
    If there are no warning lights and the ready light is on, it should go if you put it in D or R. Do the indicators for those gears come on on your dash or is it staying in P?
  18. bisco
    52,863
    i would ask luscious, if someone here doesn't have an answer
    jerrymildred likes this.
  19. Andrea L Chase
    It goes into gear (P and D light up).
    So odd. Put the gas cap on wrong, the red triangle of death. Catalytic converter gone, nada!
    jerrymildred and bisco like this.
  20. jerrymildred
    11,517
    14,171
    Tampa, FL
    Well, since you'll need to take it to a shop to get a new cat installed, they can figure out that issue as well. Just too bad you can't drive it there.
