2006 Prius A/C Fault Codes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dschwartz1957, Sep 12, 2018.
Tags:
  1. dschwartz1957
    dschwartz1957 Junior Member
    Massachusetts
    My 2006 Prius has 195,000 miles on it. In August, the A/C stopped working and only blows warm. There are no warning lights on the dash, but my mechanic downloaded several HVAC (and other) fault codes from the diagnostic port.
    • B1433 HVAC servo
    • B1421 HVAC solar sensor (which I read on PC is not a real issue)
    • C1241 ABS too low/high volt
    He also checked the coolant pressure which was under 50lbs. My mechanic has only worked on gen1 Prius A/C, which uses a conventional compressor. So this seems like a dealer or specialist job. Given the high mileage I am wary of spending a lot of money on A/C repair. The car will also need new tires before winter.
    Any ideas about the meaning of these codes and a ballpark range of repair costs?
    I have had mixed luck with Toyota dealer service departments in Massachusetts (west and north of Boston) and am open to recommendations.
    Thanks,
    David Schwartz
    2002 Prius - 196,000 miles
    2006 Prius - 195,000 miles
    2014 Prius - 34,000 miles
  2. Patrick Wong
    18,214
    6,530
    My recommendation is that you should add a little R-134a to the system.
    jerrymildred likes this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Agreed, Patrick. Sounds like low freon. Filling it won't cost much. Then see if it fixes it and if it leaks out again.
  4. ChapmanF
    19,059
    What did he think it should be? 28 psi is the threshold where you get a low pressure DTC....
    -Chap
  5. Patrick Wong
    18,214
    6,530
    My belief is that the 50 psi reading is with the system at rest. If that reading is on the low pressure side with the compressor running, then I agree that the system is actually overcharged.
  6. Al Bundy
    Al Bundy Member
    140
    69
    florida
    the prius takes a special freon for hybrids only..
    my local guy didnt know this and it smoked the compressor with standard freon
    be sure they use the right stuff
    Fern1461 likes this.
  7. Patrick Wong
    18,214
    6,530
    The issue is NOT the R-134a. The issue is use of incorrect compressor oil. Use pure R-134a w/o oil and you will be fine.
    jerrymildred and Al Bundy like this.
  8. ChapmanF
    19,059
    To the best of my knowledge, there is only one pressure sensor in the system, and it's in the liquid line near the sight glass. The same sensor, I believe, is responsible for the high-pressure limit (which would never be seen unless the compressor is running) and the low-pressure limit (which would never be seen at that location unless the compressor is stopped). I think the purpose of the low limit is to prevent starting the compressor without some minimal charge present.
    I did find another spot in a (Gen 1, because it was handy) manual, that suggested checking for at least 57 psi when doing a leak check, so I guess I'm on board with this being a bit low.
    -Chap
